Advise on shock absorbers.
03 Nov 2024 19:47 #258168 by bobearington
Hi all. New here and new to owning a Jimny. Loving it so far but need some advise. I think the shock absorbers have had their day as it’s a very bouncy ride even just on roads and when I get up to 40ish I get quite a bit of judder on the steering.
can anyone advise on shocks to buy that fit a Jimny that’s got a lifting kit and that would make for a smoother drive. Mostly road driving so something that’s quite solid I guess.
Any help would be great!
03 Nov 2024 19:53 #258170 by fordem
Replied by fordem on topic Advise on shock absorbers.
The "lifting kit" is going to impact your choice of shocks, so start by telling us what kit you have.
03 Nov 2024 20:00 #258171 by bobearington
Sorry I’m going to come across like an idiot, bear with me I’m new to all this. I believe it’s a black raptor kit but I’m not sure if it’s 2” or 4” etc. is there a way of measuring the springs to know what has been fitted?
03 Nov 2024 20:05 #258173 by fordem
Measure the height from the hub center to the wheel arch directly above and ask someone to compare it to their gen 3 - the reason for going from the hub center is that this eliminates measurement differences caused by tire size or pressure.
03 Nov 2024 20:19 #258174 by bobearington
Makes perfect sense. It’s 19” from hub centre to wheel arch. If someone has a gen 3 they can compare too if appreciate
03 Nov 2024 20:54 #258177 by Busta
Replied by Busta on topic Advise on shock absorbers.
A bumpy ride comes as standard on a Jimny so don't expect it to float along like a Citroen. But there are some things that can make it worse. If the lift kit is reasonably new (from memory black raptor only appeared on the Jimny market a few years ago) it's unlikely to be the shocks. One major contributor is tyre pressure, and as you have larger than standard tyres you may want to play about to see what works best for you. Logic says bigger volume tyres need lower pressure to carry the same load.
Time to create page: 0.324 seconds
