Picking up new Auto Jimny Run in period
20 Sep 2024 17:42 #257609 by jlines
I've never bothered with any sort of run in period with my new Jimnys. I picked them up and they went straight onto the motorway at 70mph to do over 80 miles home. They are hardy engines and liked to be worked. So long as you're not redlining the rpm then I would say you're good to go.
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
21 Sep 2024 03:10 #257612 by Chicken
If it doesn't say in the manual then the general advice is
- keep the revs below 3,000 for the first few hundred miles;
Hard to do at highway speeds in a Jimny I imagine, especially a 4 speed auto.
I guess I will do a few runs to the beach and just take it easy as much as possible.
Ducked into the dealer this morning to see how things are going, its basically done, just waiting for underbody and engine bay rust protection.
I should have taken a few snaps looks pretty good on the ironman gvm upgrade 2 inch lift with 215/75/r15 Kumho AT52s, the ironman bullbar and snorkel.
its addictive modding isnt it, still so many things I want to do, the long range tank will be useful here, the towbar, mostly for a decent recovery point on the back, underbody protection, probably starting with the radius arm points and a winch as to be fair will probably be going out solo for the most part.
Then you have to think of a name ?? :p
The following user(s) said Thank You: gv42, Soeley
21 Sep 2024 10:58 #257616 by Busta
The towbar isn't rated for recovery. Towing forces are much lower than recovery forces. If you do use it, make sure you take up all the slack before applying any force. Snatching with the towbar could easily lead to damage to the towbar or chassis.
21 Sep 2024 11:12 #257617 by Chicken
Are you sure ? Im not going to use the tow ball, just the hitch where the tow ball goes you can usually put the pin through and use a soft shackle I thought that was generally considered a pretty good recovery point ?
21 Sep 2024 12:43 - 21 Sep 2024 12:46 #257618 by Lambert
He's absolutely spot on. The tow bar is designed to take a steady load applied relatively gently. The shock loading involved in a recovery is potentially huge even if done correctly with a suitable kinetic energy recovery rope. Using a normal snatch strap or worse a static extension strap is going to put way too much energy into the tow bar it's hardware and fixing points. Carefully using a winch to incrementally ease yourself backwards to safety is going to do the least damage but even then you are at risk of ripping it apart. The tow bar is designed for drawing a free moving object behind you not for dragging the vehicle backwards when up to it's axles in gloop or wedged on a stump or rock. Proper recovery points that apply force directly in line with the chassis and not offset causing a peeling motion are best especially used in tandem with a bridle.
Last edit: 21 Sep 2024 12:46 by Lambert. Reason: Spelling
21 Sep 2024 12:56 #257619 by DrRobin
My factory fit tow bar uses the same mounting points as the rear recovery points (it stops me mounting heavy duty rear recovery) and is heavy duty, but I take Lambert’s point.
I drilled and fitted two eye bolts close to the tow bar fixing and use a bridle so the load is as close to the chassis points as possible.
The tow bar is rated to 1,300kg, but that is in the centre, so must be higher at the chassis mount point.
I only intend to use the rear recovery points to tow my own Jimny if it gets stuck, like it was a couple of weeks ago, when someone used a winch on to my bridle, it came out no problem. I think it all depends on how likely it is you are going to be really stuck and perhaps you shouldn’t have chanced that big muddy pool?
I might tow a car in the snow and ice, but the load would be minimal then. If I was to recover someone else chances are you would use front recovery points, which I will fit as soon as they are back in stock.
Robin
Time to create page: 0.312 seconds
