Fabbricare Protezioni (-fabrication of protection)
- EmiJimny02
05 Sep 2024 11:35 - 05 Sep 2024 11:36 #257444
by EmiJimny02
Fabbricare Protezioni was created by EmiJimny02
Buongiorno a tutti, mi chiedevo se qualcuno ha le misure per fabbricare protezioni per il jimny 1998-2018..
saluti.
saluti.
Last edit: 05 Sep 2024 11:36 by EmiJimny02.
05 Sep 2024 20:35 - 05 Sep 2024 20:36 #257447
Replied by Soeley on topic Fabbricare Protezioni
Just done a Google translate:Buongiorno a tutti, mi chiedevo se qualcuno ha le misure per fabbricare protezioni per il jimny 1998-2018..
saluti.;
Sorry, I can't help with that, but someone might be able to ?Good morning everyone, I was wondering if anyone has the measurements to make protectors for the 1998-2018 jimny..
Greetings.
Last edit: 05 Sep 2024 20:36 by Soeley.
06 Sep 2024 07:51 - 06 Sep 2024 07:58 #257454
Replied by yakuza on topic Fabbricare Protezioni (-fabrication of protection)
My experience with these things are not OK. The dwg or stp files you might find are often bad for production or has bad dimensions or has a not an ideal design.
And if I put any designs out there they will be misunderstood or misused and used by people with lesser skills.
And then I get the blame for them ruining their materials or car or equipment by their own lack of skills.
If you are skilled enough to make stuff you are also skilled enough to design them better.
For making one off stuff it is most often cheaper to just buy it ready made if it can be bought.
And that is coming from me having skills and access to proffessional 3D tools and manufacturing resources.
I have designed myself and make adapter plates for engine conversions for the Suzuki. Tried first to look at existing kits but they are so way off in the geometry that there is only faults to be copied. Designed my own and they fit like a glove.
Also made machining drawings to make the 4.16 to 1 gear wheel from 410/410 transfer gears but unskilled people blaming me afterwords made me remove the drawings from all on line websites. They will not return but have been shared with many skilled friends I trust in the suzuki community.
Sorry for being a party pooper but i cannot recommend to anyone to use anything they find or get online or recommend others to upload or share such files.
Ok for simple things and for skilled craftsmen it could work, but one must be very careful as in all tips or hints one gets online for mods of any kind.
Last edit: 06 Sep 2024 07:58 by yakuza.
- EmiJimny02
06 Sep 2024 08:15 #257455
by EmiJimny02
Replied by EmiJimny02 on topic Fabbricare Protezioni (-fabrication of protection)
ovviamente se pubblichi progetti non hai mica responsabiltà...
- EmiJimny02
06 Sep 2024 08:17 #257456
by EmiJimny02
o se qualcuno possiede qualche protezione comprate da case che producono pezzi offroad, potrebbe misurarli e mandare le misure o magari fare un disegno con le relative misure.....
