Overhearing issues
25 Aug 2024 11:24 #257340
by Conev
2002 Manual M13A jimny RHD
2" Black Raptor Lift kit
Ironman 4x4 steering Damper
8" steel wheels 215/75/15 AT100
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
Replied by Conev on topic Overhearing issues
The highest temp i got before the whole system coolant flash was 109 degreesC. Now the max is at 105-106 on hill climb on a hot day . My only question is the temp gauge on the dashboard failing then because when is at 106 degreC its well above middle but when the car is at 104 is steady a bit below middle .
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
25 Aug 2024 15:04 #257344
by Motacilla
Replied by Motacilla on topic Overhearing issues
"Is there a possibility of a bad temp sensor ? [...] What should my next step be ?"
On your Jimny, the temp gauge is connected to the computer, not the temp sensor. That is, the computer is monitoring all of the engine conditions, and sending out signals to the gauge in the dashboard.
The signals to the dashboard gauge are not really intended to be one-to-one needle increments to get an exact temperature reading. As fordem said, the gauge is not a precision instrument. It is just there to look cool -- newer Jimnys don't even have one -- and if you did ever have a real overheating issue the car would let you know.
Put another way, the OBD temperature reading and the dashboard temp gauge reading are coming from the same place, the computer. They are not disagreeing... because they can't. And replacing the gauge will not get you any greater precision, because that's not really what the gauge is for.
There's not really anything wrong with your Jimny. But you can confirm the actual coolant temp as fordem describes, if you are concerned. And of course you can replace the gauge if that gives you peace of mind!
Side note, most modern cars have no temp gauge at all (like the new Jimny) or have one that doesn't move even when the temp changes. This is because it is not necessary for a driver of a modern car to monitor coolant temp, and the manufacturers found that a moving needle just caused unnecessary stress...
25 Aug 2024 16:38 #257347
by Conev
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
I hope that is the case , partly i agree with you . But how would the car let me know that is overheating without giving attention to the needle going above middle ?
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
27 Aug 2024 07:47 #257362
by Busta
Replied by Busta on topic Overhearing issues
If the needle is in the red it is overheating. Anywhere outside of the red is fine. That's about all anyone ever needs to know about modern temperature gauges, hence them being replaced by a light.
Time to create page: 0.099 seconds
