Axle breather extenders
21 Aug 2024 12:32 #257264 by me101
Replied by me101 on topic Axle breather extenders
I have mine rolled up between the battery and side panel. You don't see them and would need to be sat in water before it takes any on. Will try and sort a pic (or my fitting link)
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
21 Aug 2024 18:14 #257268 by me101
21 Aug 2024 18:31 #257270 by DrRobin
Replied by DrRobin on topic Axle breather extenders
I think people might run the breather pipes up the outside of a snorkel. I couldn’t put them inside it. Pressure drop at wide open throttle is probably quite significant.
That said. I’d just terminate the breathers at the top of the bulkhead in the engine bay. I have no intention of driving through water deeper than the bonnet. And the bow wave and wake of a moving vehicle will mean the water level would be significantly lower in the engine bay than on the outside of the vehicle.
Should water really reach that level you’d likely have more issues than potential water in the diffs IMO.
Yeah, I will probably abandon the snorkel, I have heard of it been done, but I am not intending to go through deep water, just want to extend the breather above the 300mm they currently are, so somewhere on the front bulkhead will do fine for me.
Robin
21 Aug 2024 21:32 #257272 by Gadget
Replied by Gadget on topic Axle breather extenders
I've got the Des-Sol breather kit. I spent a lot of time faffing around with home-brew setups using garden hose and jubilee clips and was never happy with the results. Have had zero issues with the DS kit and don't think about it any longer.
That's good to know and exactly what I want.  Did you connect up the transfer case and gear box and was the transfer case accessible without dropping it?
Robin
I've connected the transfer case, which is very difficult to reach, but can be done if you've got small hands! I've not hooked up the gearbox as the supplied manifold only has ports for diffs and TC, plus I'm never going to go that deep in water (hopefully!)
22 Aug 2024 06:18 #257274 by RumbleAndSway
Installation Guide: des-sol.co.za/wp-content/uploads/2021/08...tions_compressed.pdf
Most of the install is easy but removing the existing breather caps was a real challenge: need a lift/ramp, breather cap removal tool and in my case, a second pair of strong hands.
I purchased through jimny wild.co.za - bundled with their no-drill-snorkel - combined UPS charges/import £75
Looks quality but too early to say if the breathers are a good investment - purchased May 24 and yet to encounter a water hazard [fitted these in preparation for winter 24/25.]
Big fan of the no-drill-snorkel - I like the increased induction sound. Only downside is fitting the steel connecting pipe to the air-box takes real patience and persistence.
22 Aug 2024 06:59 #257275 by Motacilla
Replied by Motacilla on topic Axle breather extenders
Good info, thanks for posting.
How do the Des-Sol breather caps seal on the vent unit? And what material are the caps made of?
Time to create page: 0.357 seconds
