Securing storage boxes to roof rack...?
- richythepom
- Thank you received: 1
21 Jul 2024 10:05 - 21 Jul 2024 10:06 #256878
by richythepom
Securing storage boxes to roof rack...? was created by richythepom
Good morning all
As per the title, just wondered what the general consensus is, please?
I'm planning on buying some sturdy plastic storage boxes for the roof rack (maybe Peli cases or similar); I know I could throw a ratchet strap or ropes over, but is there a neater solution, that's perhaps more secure, less likely to result in boxes being nabbed and possibly even semi-permanent?
Thanks all - again!
Thanks all - again!
Last edit: 21 Jul 2024 10:06 by richythepom.
- Roger Fairclough
- Thank you received: 225
21 Jul 2024 13:40 #256879
by Roger Fairclough
Replied by Roger Fairclough on topic Securing storage boxes to roof rack...?
You need to consider that the max. load on the roof is, from memory, 35 kg and that includes the rack. There have been discussions on this problem before and a number of members believed that a better option is a trailer. It is certainly worth thinking about.
Roger
Roger
The following user(s) said Thank You: richythepom, HappilyNorth
- richythepom
21 Jul 2024 14:03 #256881
by richythepom
Replied by richythepom on topic Securing storage boxes to roof rack...?
Thanks Roger, I'll certainly be considering a trailer for larger loads (and the dump etc.); I was thinking more about a box or two on the roof for things like welly boots, wet weather clobber and such like - nothing overly heavy.
- Thank you received: 2001
21 Jul 2024 18:19 #256885
Replied by Lambert on topic Securing storage boxes to roof rack...?
Small U bolts through the bottom of the box and under a spar on the rack same as is used on the big rooftop boxes you get from the likes of thule etc.
- The Coil Spring
- Senior Member
- Thank you received: 6
22 Jul 2024 19:16 #256918
by The Coil Spring
Replied by The Coil Spring on topic Securing storage boxes to roof rack...?
Bicycle inner tubes. I use them to strap on snowboards and surfboards. They don't smack your face like bungee cords do. But there are tubes with different finish. Some can cause black smudges on the items you are fastening, but other tubes have a more glossy surface and it's them you want. The rubber deteriorates by UV light though, so they can't be used as permanent solution.
Time to create page: 0.164 seconds
