2003 Suzuki Jimny jb33 transmission issues
27 Jun 2024 18:28 - 27 Jun 2024 18:34 #256478 by Josh
Have a good day.
I own a 2003 Suzuki Jimny JB33, which I bought two weeks ago. It has a G13BB engine and an automatic transmission. My problem is that when I put the vehicle in gear, it only reaches 2000 RPM. However, when in neutral, it revs normally. I have replaced the speed sensor, transmission fluid, and transmission filter, which helped a little, but the issue persists. I can’t drive uphill, but on flat roads, it starts slow before eventually picking up speed. What could be the problem?
Last edit: 27 Jun 2024 18:34 by Josh.
28 Jun 2024 03:23 #256485 by Lambert
Have you checked for any fault codes on the transmission?
28 Jun 2024 04:27 #256487 by mlines
Blocked catalytic converter?
Sent from my ThinkPhone by motorola using Tapatalk
03 Jul 2024 01:37 #256605 by Josh
So quick update my o2 sensor I missing the port on the exhaust has been welded or do not know of it can so and Al so the coil packs or borken I have to by a scan tool
Time to create page: 0.193 seconds
