Frame tube plugs - Good or bad idea?
16 Jun 2024 08:48 #256303 by Roger Fairclough
Pressure wash the tubes, allow to dry and then using a long handled brush apply your choice of rust preventative, primer and bitumastic paint of your choice and then if you wish fit the plugs remembering to seal them with a builders mastic or RTV.
Roger
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
16 Jun 2024 17:54 #256311 by DrRobin
All good points, thanks guys.
I am going to clean the tubes out, then treat the inside, but most likely not fit the plugs.
What I might do and it depends on how easily they are to fit and remove, is fit them for off-road days/weekends and then remove them afterwards. The logic is fit them to stop mud and muck entering, then remove to let the tubes breathe.
I have an off-road day coming up, then BigJimny and a couple more off-roads days later in the summer so we will see how long it takes to fit and remove, if it is only 30 minutes, it might be worthwhile.
Robin
Time to create page: 0.207 seconds
