Re:Power Steering Fluid Leak and Whining Noise
31 May 2024 16:32 #256148 by vinpoldo
JIMNY JB43 2014
35,000 Kilometers
Automatic Transmission
After having my engine and transmission mounts replaced and spent $$$ on it, I encountered a new problem:
Day 1: I noticed a whining noise in the driver side of the engine. I looked and found that somewhere in the power steering pump is wet. Fluid is still in optimal level
Day 2: I saw a drop of PS fluid on the ground and the whining noise still there.
Could this be Power Steering Pump issue? Is this common in JB43?
01 Jun 2024 02:57 #256154 by Lambert
It's not unheard-of but they are usually fairly good. Was it disturbed during the recent work?
01 Jun 2024 05:16 #256155 by vinpoldo
I did not see the repair itself. But that's my theory. They might have messed up something when they replaced the mounts.
This the view from below:
01 Jun 2024 12:47 - 01 Jun 2024 12:49 #256156 by mlines
There is a small metal elbow pipe on top of the steering unit. This is fragile and splits with age. It is suspiciously near the engine mount and could have been knocked. Your first picture shows the elbow. Look carefully at it for a split
Sent from my ThinkPhone by motorola using Tapatalk
Last edit: 01 Jun 2024 12:49 by mlines.
02 Jun 2024 00:54 #256157 by vinpoldo
I don't see any pipe near the engine mount.
But there's an area around the power steering that's kinda wet.
Sent from my Pixel 6 using Tapatalk
02 Jun 2024 00:56 #256158 by vinpoldo
This is the area that is wet, I'm guessing PS fluid. But the fluid level in the reservoir is okay.
