Considering wax oil treatment,
21 May 2024 08:27 #256025
by Porthos
2020 SZ5
Considering wax oil treatment, was created by Porthos
Has anyone gone down the wax oil treatment road. Mine can be done for around £500 locally. Is it worth doing?
2020 SZ5
- Thank you received: 673
21 May 2024 08:54 #256027
Replied by DrRobin on topic Considering wax oil treatment,
Most people who intend keeping their Jimny go for underbody treatment. In addition to Waxoyl there is also Dinitrol and Lanoguard.
I am considering Dinitrol for my Jimny, but make sure the place doing the job properly cleans and dries the underneath first, this is usually a 2 day job.
Robin
Robin
21 May 2024 11:16 #256033
Replied by Soeley on topic Considering wax oil treatment,
I believe Lanogaurd and Waxoyl need redoing every 12 to 24 months. Dinitrol is much harder wearing, is jetwash proof and only needs touching up if you manage to scrape some off, on rough ground.
When I had mine done in 2019, the garage offered a free anual inspection and touch up, if required
- Thank you received: 2000
21 May 2024 19:25 #256040
Replied by Lambert on topic Considering wax oil treatment,
I use waxoyl and am aware that it needs a top up every year on high abrasion surfaces like the leading edges of axles and in the wheel Wells but that's to be expected on a working vehicle. The rest is as good as when I applied it 3 years ago.
22 May 2024 11:32 #256048
by Busta
Replied by Busta on topic Considering wax oil treatment,
That depends on what sort of job they are going to do. To do it properly they will need to remove the wheels, arch liners, headlights, both bumpers and the exhaust backbox. £500 would be reasonable for an extensive job, but expensive for someone to quickly spray some waxoyl around the bits they can see.
I'd also recommend something better than waxoyl if you're not planning on topping it up every so often.
- Roger Fairclough
- Thank you received: 225
22 May 2024 12:26 #256049
by Roger Fairclough
Replied by Roger Fairclough on topic Considering wax oil treatment,
The Gen.4 has extensive underbody treatment and a 12 year anti-corrosive treatment. This needs a check every a2 months but my local main agent told me that Suzuki would accept the stamp of a reputable dealer if I didn't want to pay £40-50 at the Suzuki dealer.
Last year I started to paint the underbody with bitumastic paint but gave up half way along when I saw how thick the Suzuki protection was. I might finish it this year, primarily because there is a small amount of rust on the front axle. It's nothing to worry about, but I am a pedantic sod and I don't like the colour of rust.
Roger
Roger
Time to create page: 0.398 seconds
