Vibration when on D or R while stepping on the Brakes/Stop/In Traffic
20 May 2024 20:35 #256019
by vinpoldo
2014 Suzuki Jimny JLX Superior White 1.3 Petrol.
I'm planning on taking my Jimny to the nearby shop to fix an issue of Vibrating when on D or R while stepping on the brake.
My diagnoses are:
*Worn out Engine Mounts (2 Trans mounts - front and 1 engine mount- rear
*Dirty Throttle Body
I've already replaced my sparkplugs but it did not resolve the issue so this is my next step.
Any recommendations?
My diagnoses are:
- Thank you received: 1984
21 May 2024 03:25 #256023
Replied by Lambert on topic Vibration when on D or R while stepping on the Brakes/Stop/In Traffic
What condition is the transmission oil in? How many miles has it done? Tend to think you may be onto something with the mounting points but check the oil for being burnt too.
21 May 2024 10:14 #256028
by vinpoldo
Replied by vinpoldo on topic Vibration when on D or R while stepping on the Brakes/Stop/In Traffic
Thanks for your reply. Can you elaborate the connection between transmission oil and the vibration on D/R? I'm really not an expert on cars and I'm learning as I go. Appreciate your inputs.
21 May 2024 10:15 #256029
by vinpoldo
I have 21,700 miles on my Jimny
21 May 2024 19:16 #256039
The transmission works by pumping oil at pressure through different galleries to activate the gears in simple terms. If the oil has degraded because of age or excess heat it will not perform correctly and this can manifest as odd vibration or general roughness of operation or slipping when it shouldn't.
24 May 2024 19:04 #256076
by facade
Replied by facade on topic Vibration when on D or R while stepping on the Brakes/Stop/In Traffic
Do you mean it vibrates when it is moving and the brake is applied, or that it vibrates when stationary and you are holding it on the brake?
If moving, check for warped brake discs or oval rear drums.
If stationary, it may be broken engine mounts/transfer mounts/rear axle mountings.
Time to create page: 0.402 seconds
