Vibration when on D or R while stepping on the Brakes/Stop/In Traffic
20 May 2024 20:35 #256019 by vinpoldo
2014 Suzuki Jimny JLX Superior White 1.3 Petrol.
I'm planning on taking my Jimny to the nearby shop to fix an issue of Vibrating when on D or R while stepping on the brake.
My diagnoses are:
*Worn out Engine Mounts (2 Trans mounts - front and 1 engine mount- rear
*Dirty Throttle Body
I've already replaced my sparkplugs but it did not resolve the issue so this is my next step.
​​​​​​Any recommendations?
21 May 2024 03:25 #256023 by Lambert
What condition is the transmission oil in? How many miles has it done? Tend to think you may be onto something with the mounting points but check the oil for being burnt too.
21 May 2024 10:14 #256028 by vinpoldo
Thanks for your reply. Can you elaborate the connection between transmission oil and the vibration on D/R? I'm really not an expert on cars and I'm learning as I go. Appreciate your inputs.
21 May 2024 10:15 #256029 by vinpoldo
I have 21,700 miles on my Jimny
21 May 2024 19:16 #256039 by Lambert
The transmission works by pumping oil at pressure through different galleries to activate the gears in simple terms. If the oil has degraded because of age or excess heat it will not perform correctly and this can manifest as odd vibration or general roughness of operation or slipping when it shouldn't.
24 May 2024 19:04 #256076 by facade
Do you mean it vibrates when it is moving and the brake is applied, or that it vibrates when stationary and you are holding it on the brake?
If moving, check for warped brake discs or oval rear drums.
If stationary, it may be broken engine mounts/transfer mounts/rear axle mountings.
