Airbag warning light on Gen 4.
13 May 2024 16:11 #255940 by Roger Fairclough
The airbag warning light started to stay on a month or so back and has now reached the point where it is on permanently. The light adjacent to the interior mirror behaves normally.
Any body got any suggestions?
Cheers.
Roger
13 May 2024 17:24 #255945 by fordem
Get the code read and you'll know why the light is on.
The following user(s) said Thank You: Roger Fairclough
13 May 2024 20:11 #255948 by facade
As fordem says read the codes.
SZViewer will read the SRS codes, you only need a compatible bluetooth dongle thingie for your 'phone/tablet.
At a guess it will be either a connector under the seat for the seat airbag or the seatbelt tensioner, or (much more likely as it is a million times more trouble and costs £££ to sort) the clockspring behind the steering wheel.
Fingers crossed it is just a loose connector from moving the seat!
15 May 2024 11:47 #255959 by Roger Fairclough
Electronics are not my strong point, so any advice on a suitable reader - and accessories needed - would be appreciated.
Cheers
Roger
15 May 2024 18:29 - 15 May 2024 18:30 #255964 by facade
You need an android/windows/linux smartphone/tablet/notepad/laptop with bluetooth, a copy of SZViewer, and a suitable dongle to plug into the OBD port above the driver's legs.
SZViewer malykh.com/soft/sz-viewer/
If you have an android phone or tablet, get SZViewer from the google play store (It doesn't work on iphones/ipads)
Download it now, and play with it, there is an emulation mode that pretends it is connected and makes up some measurements and error codes to show you how it works.
The dongle that I use www.lonelec.com/product/obd2-wireless-bl...ve-data-reader-v1-5/
Everyone else in the entire Universe just uses the cheapest eBay/Amazon/Aliexpress dongle for £5, but I have a couple of different versions of those, including a white one with "Proscan Automotive" on it, and absolutely nothing that I can do will get them to work, so I bought the Lonelec one, as I have one of their motorcycle interfaces that works perfectly.
Last edit: 15 May 2024 18:30 by facade.
15 May 2024 18:40 #255965 by DrRobin
I have a Proscan Automotive that apparently has a genuine chip (probably a genuine copy as the original ones are no longer made). My Proscan works on every vehicle I have/had including a Gen 3 and a Gen 4.
I also have an Autel ML629 handheld reader that also works on every car, although on a Jimny if you hit SCAN it seldom finds the correct protocol for a Jimny, but you can see fault codes if you go in to OBD option.
SZViewer is considerably cheaper and does everything the Autel does, except I am an Apple man so have to take my laptop out.
Robin
The following user(s) said Thank You: Roger Fairclough, Filipao
Time to create page: 0.162 seconds
