Jimny LED fogs lights and DRL
02 May 2024 19:47 #255845 by Obarno
For those with the early type 1 bumper if you wish to fit LED spots with DRL you need 2 mounting brackets that fit the original points inside the front bumper. The part numbers are 35526 81A30 and 35566 81A30. The socket on the new spots is different from the socket for the old lights so you will need to improvise!
I bought an electrical connection for the lights that connects direct to the car battery and when the voltage is high enough after starting the engine, they turn on.They turn off when the battery voltage drops when the engine is switched off. There is also a connection to the side lights that dims the DRL when the lights are on.
First pic is Fog lights, 2nd is DRL dimmed by side lights being on and 3rd is the DRL.
Time to create page: 0.169 seconds
