Re:LED bulbs for Gen.4 rear lamps.
- Roger Fairclough
Topic Author
- Thank you received: 225
19 Apr 2024 18:48 #255676
by Roger Fairclough
LED bulbs for Gen.4 rear lamps. was created by Roger Fairclough
I would like to change the std. rear bulbs for LED options but Martin doesn't list them. Does anybody know of a source?
Cheers
Roger
Cheers
Roger
- Thank you received: 667
19 Apr 2024 18:54 #255677
Replied by DrRobin on topic LED bulbs for Gen.4 rear lamps.
If you mean the rear lights, brake lights and turn indicators, I think you have to change the whole fitting, no just the bulb. There are quite a few sellers on eBay, ETC, but nearly all of them don't have a fog light which makes them unsuitable for UK roads.
Jimnystyle sell one which does have fog light, but it's £262
streettracklife.com/products/jimnystyle-...or-suzuki-jimny-2018
Robin
Robin
- Roger Fairclough
Topic Author
19 Apr 2024 20:27 #255682
by Roger Fairclough
Replied by Roger Fairclough on topic LED bulbs for Gen.4 rear lamps.
Cheers Robin. The w/shop manual indicates that the bulbs are capless and can be removed, but thanks for the response.
Roger
Roger
- Thank you received: 1999
20 Apr 2024 03:35 #255684
Replied by Lambert on topic LED bulbs for Gen.4 rear lamps.
It's because the law says you are not supposed to use led in lamps not designed for them. Though most of the time that is monitored in head lamps more often than tail lamps.
- rogerzilla
20 Apr 2024 06:08 #255687
by rogerzilla
Replied by rogerzilla on topic LED bulbs for Gen.4 rear lamps.
If you do change them despite the regs (LED brake lamps illuminate quicker, which may help safety), bear in mind that many LEDs will cause an error because the car sees lower resistance and assumes a bulb or circuit has failed. Canbus-friendly ones should work but get a money-back guarantee.
Apart from headlamps, LED replacements aren't currently checked for at MOT time but they do contravene construction and use regs, and could get you a ticket from the police.
20 Apr 2024 11:06 #255689
by Bob9863
Replied by Bob9863 on topic LED bulbs for Gen.4 rear lamps.
This place in Australia has them for £34 and they will post to the UK no problem.
ozjimny.com/products/spectr-led-fog-ligh...riant=42291721961697
Much cheaper option, I've got a set coming on Tuesday according to the tracking.
Time to create page: 0.195 seconds
