Re:Wiring advice - I'm stuck!
28 Mar 2024 10:18 #255267 by me101
Hi. I run a light bar on the front of my roof rack. A few months ago, it started being a bit hit and miss when switching on. Sometimes had to switch on / off a few times before it came on. I changed the switch, no difference, so changed the relay, still no change. However, I have replaced the relay again thinking it may be a dodgy one, and noticed something else now. With the relay not connected, the switch illuminates when on, but with the relay connected, no light on the switch?? Do we think light bar itself, or possibly something else?
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
28 Mar 2024 13:50 #255269 by lookonimages
me101 wrote: Hi. I run a light bar on the front of my roof rack. A few months ago, it started being a bit hit and miss when switching on. Sometimes had to switch on / off a few times before it came on. I changed the switch, no difference, so changed the relay, still no change. However, I have replaced the relay again thinking it may be a dodgy one, and noticed something else now. With the relay not connected, the switch illuminates when on, but with the relay connected, no light on the switch?? Do we think light bar itself, or possibly something else?
Cheers
Depends on wiring, just note jimny is negative wired.
You do not say where you pick up your power from unless here is pic that I cant see in tappatalk.
So it depends. Sorry best I can add for now
28 Mar 2024 14:06 #255271 by me101
Replied by me101 on topic Re:Wiring advice - I'm stuck!
Hi, it runs direct from the battery so can be used with out ignition. Worked perfectly for a year or so.
28 Mar 2024 14:30 #255272 by DrRobin
Do you have a wiring diagram you could share? Or, perhaps a sketch then take a photo of it?
I suspect a bad connection, if the indicator on the switch lights with no relay connected, it sounds like a bad connection is not letting enough current to flow. Depending on how it's wired (positive or nagative switch), I might suspect the common, possible connected to the metal work of the car.
Robin
28 Mar 2024 14:34 #255273 by me101
I am at work, so no pics, but I will have a check on connections. I wired direct to battery (+ve and -ve) to try and avoid bad earth issues, but it has seen a few water crossings since fitting!
28 Mar 2024 23:13 - 28 Mar 2024 23:13 #255283 by Hughes
Is the light bar a reputable brand? I've not had much luck with generic chinese LED lights. Test it by wiring direct to battery. The intermittent issue and the mystery switch light may be indicative of a failing circuit board in the light itself.
Last edit: 28 Mar 2024 23:13 by Hughes.
Time to create page: 1.035 seconds
