Rear axle hub seal leaking(?)
22 Mar 2024 07:05 #255200
by Stefan
Rear axle hub seal leaking(?) was created by Stefan
Greetings all,
So I've discovered recently my Jimny developed a bit of an oil sweat at the rear axle on the left-hand side, where the hub assembly bolts to the axle. Not very clued up to the inside of the Jimny axles yet, so I can't say if it would be the hub seal or the flange gasket. The Jimny is used every day so I can't strip it to see what's wrong. Anyone that might know what's leaking inside? Thanks.
22 Mar 2024 09:00 #255201
by Hughes
Replied by Hughes on topic Rear axle hub seal leaking(?)
If thats gear oil, most likely to be the bearing is shot. Main weak point on these axles, (in my view) I regularly make river crossings and I end up replacing both sides pretty much annually.
The bearings are a large clearance to begin with (C4 I think?) and when they wear, the axle seal inboard of the bearing won't take up the radial clearance enough to stop oil from leaking out. The seal on the bearing itself seems to do little more than keep the grease in the rough vicinity of the rolling elements.
Or could be (but less likely) a slave cylinder.
Only a few minutes to remove that wheel and brake drum to have a peek (you may need to wind the shoes in manually if the drums are worn), you'll soon see where the offending liquid is coming from.
I've done heaps of rear wheel bearings, sing out if you have any questions about it
22 Mar 2024 12:05 #255204
by Stefan
Replied by Stefan on topic Rear axle hub seal leaking(?)
Thank you Hughes for the reply.
I did a smell test and it definitely smells like the gear oil. But it wouldn't hurt to check inside the drum while I'm at it since it's a 2012 model and I don't think any maintenance has been done in that area in a long time. I did replace the pinion seal on the rear axle a while ago too. Thank you, I'll be sure to contact you should I need more info.
23 Mar 2024 07:39 #255211
by Stefan
Hi Hughes,
Okay so, can you give me some info on this. What thpe of bearing is is? Standard taper or ball bearing? What size is the bearing? I requested a quote from the stealership, quite a high price (labour excluded). They also added extra parts that they say normally break during pressing of the bearing. Any insight would be most appreciated.
23 Mar 2024 09:37 #255213
Replied by jackonlyjack on topic Rear axle hub seal leaking(?)
www.jimnybits.com/jimny-rear-wheel-bearing-kit-abs-version.html
This is what you will need
You will need to cut the abs ring off with a grinder with care
Also make sure you remove the sensor from axle casing before pulling out the shaft
23 Mar 2024 17:19 #255219
Replied by mlines on topic Re:Rear axle hub seal leaking(?)
Being the BigJimny Website, this is the part you need.
www.bigjimny.com/store/rear-wheel-bearing-kit-abs.html
Sent from my ThinkPhone by motorola using Tapatalk
Time to create page: 0.154 seconds
