Carbureter overfueling?
- Ayoung7530
18 Mar 2024 19:25 #255148
by Ayoung7530
Carbureter overfueling? was created by Ayoung7530
Hi all my 57 plate jimnys cat has been glowing hot and melting the actual cat itself when this happens I lose all power and the engine wont rev does anyone have any ideas ? Tia
18 Mar 2024 19:56 #255150
by Busta
Replied by Busta on topic Carbureter overfueling?
Normally the first cat breaks up and blocks the second cat, restricting the exhaust and causing it to get very hot.
Your Jimny doesn't have a carburettor. They disappeared in the early 90s.
The following user(s) said Thank You: Ayoung7530
- Ayoung7530
18 Mar 2024 21:53 #255154
by Ayoung7530
Replied by Ayoung7530 on topic Carbureter overfueling?
Any idea what is causing the first cat to break up in the first place?
- Thank you received: 673
18 Mar 2024 22:27 #255155
If the first CAT has disintegrated and blocked the second CAT, take the second CAT off and shake it to see if lots of dust comes out. If it does then you might need to replace both as they are very difficult to clean and unblock.
Your picture of the CAT glowing red hot seems to suggest it is hot on the exhaust side, not the engine side, is that correct? If the second CAT was blocked I would have thought that it would be the engine side which was glowing red, not the exhaust side.
Either way it needs sorting out before it sets fire to something.
Robin
Replied by DrRobin on topic Carbureter overfueling?
just old.Any idea what is causing the first cat to break up in the first place?
Robin
20 Mar 2024 08:23 #255183
by Scimike
Replied by Scimike on topic Carbureter overfueling?
How is the fuel consumption?
The fact it looks hotter after the Cat doesn't look like a blockage, I would expect it to be cooler as its blocked?
Heat after the Cat suggests it's burning something, all you have available is petrol, hence why I am asking if the Mpg is poor. As its Injected is it possible the exhaust sensors have it wrong? If you could get it on a gas analyser it may help.
Just another angle open for comment. All I know for sure is it's going to kill you Cat eventually.
- Ayoung7530
20 Mar 2024 09:16 #255184
by Ayoung7530
It has moments when it’s as if it’s flooding the engine (this is when the glowing is bad)and I can near enough see the fuel gauge go down so I’m assuming there’s excess fuel getting in there somehow. Someone I asked said to try the coils as they might be poor and causing the ecu to play up and put more fuel through.
