I hate myself for asking it but DRL/fogs?
- Thank you received: 2001
02 Mar 2024 13:10 #254749
I hate myself for asking it but DRL/fogs? was created by Lambert
I'm finally coming to the conclusion that my beloved quasar grey is actually less visible to other road users than the avengers helicarrier with the retroreflecors switched on. To this end I am investigating the idea of daytime running lights. Is there a bolt in kit that augments the front fog lights without duplicating them? Gen3.
- Thank you received: 673
02 Mar 2024 13:28 - 02 Mar 2024 13:29 #254751
Replied by DrRobin on topic I hate myself for asking it but DRL/fogs?
You can get replacement LED fog light units that have DRL in them from several places, although most aren’t CE marked.
I did find one set which were CE marked for about £140, but would have to look the link up.
When I looked at the back of my fog lights the bolt heads had rust on them so decided they were not going to come out easily. That’s why I fitted the Ring Lyra LED in the front grilles on my Gen3, about £55-£60. Lyra are approved and sense battery voltage to switch on and off. The also wire in to the position light and dim at night.
I just used a Dremel to cut through the grille, it was fairly straight forward.
Robin
Robin
Last edit: 02 Mar 2024 13:29 by DrRobin.
02 Mar 2024 13:34 #254752
Replied by Lambert on topic I hate myself for asking it but DRL/fogs?
Hmm would definitely need conformity markings, don't want the hassle of them failing a test.
02 Mar 2024 13:50 - 02 Mar 2024 13:52 #254753
These weren’t the combined fog/DRL I found before, can’t find those now but look similar.
www.goingfast.com/en/led-daytime-running...g-light_1499003_1491
To make them automatic you might also need a control box, unless they have it built in.
These were the Ring DRL I fitted, also approved
www.halfords.com/motoring/bulbs/ring-lyr...XZ00hcBoCVk4QAvD_BwE
Ring Lyra has the automatic control built in, just 3 wires, battery +, ground and front position lights.
Robin
Robin
Last edit: 02 Mar 2024 13:52 by DrRobin.
- rogerzilla
02 Mar 2024 14:04 - 02 Mar 2024 14:05 #254755
by rogerzilla
Replied by rogerzilla on topic I hate myself for asking it but DRL/fogs?
Do the gen4 units fit? I think they're both Valeo and they might be a common fitment. Obviously you'd still need to add DRL wiring.
Last edit: 02 Mar 2024 14:05 by rogerzilla.
02 Mar 2024 14:09 #254756
According to some listings they might well be.
Time to create page: 0.443 seconds
