Steering Box
02 Feb 2024 14:05 #253963 by Roger Fairclough
Replied by Roger Fairclough on topic Steering Box
As Lambert said, there isn't a boot to split as the CV joint is inside the swivel housing. The exposed thread does not have a nut. The female thread is inside the U/joint that is on the end of the steering column. A momentary locking of the steering is probably either the CV joint or one of the king pin bearings that is badly corroded due to water ingress. This may not show up on a rocking test but if you remove one or both steering ball joints and manually turn the wheels, a roughness or reluctance to turn is reason enough that the kingpins are past it.
Roger
02 Feb 2024 17:29 - 02 Feb 2024 17:32 #253973 by Scimike
Replied by Scimike on topic Steering Box
^^^^^ As above, I would also assume CV joint in one of the front swivels. I noticed on a kingpin rebuild that if you don't have the CV in exactly the correct position it will jam the swivel as you try to turn it. The circlip keeps it held in the correct position, bit if the CV is failing and things are moving outside of "normal" a jam as the swivel turns is possible.
With the steering ball joints removed and the wheel off you can move each swivel by hand, should be a nice smooth movement. Sticky or uneven force is possibly kingpin bearings or CV. Which ever it's time to take it apart and check, not a big job.
Last edit: 02 Feb 2024 17:32 by Scimike.
02 Feb 2024 21:44 #253983 by LeoAioria23
Replied by LeoAioria23 on topic Steering Box
Thank you, just took a look at the ball joints for excessive grease, they don't look bad at all. I'm not seeing many signs of wear. Does it look like i need to remove the wheels for a deeper look?
03 Feb 2024 10:40 #253986 by Roger Fairclough
You have shown pictures of the steering swivel. If you go to "shop" at the top of this page and then enter steering ball joint you will see a picture of the ball joints. I do not wish to be rude, but working on the steering/suspension components of a car and any other part for that matter requires knowledge and the appropriate tools. You are well advised to seek help, so I would advise you to tell us where you live and then, maybe, there is a forum member who knows someone.
Roger
03 Feb 2024 14:58 #253995 by jackonlyjack
Replied by jackonlyjack on topic Steering Box
From past experience I had no sign of oil on my swivel...... But when I stripped it down the lower kingpin bearing just fell apart
I'm with other people get a ball joint splitter
Then turn side to side you will be able to feel if it's not happy
Also when did you change kingpin bearings last?  if you go through water/mud regularly you'll be doing well to get 2 years lifespan
Time to create page: 0.189 seconds
