whine possibly from gear box
16 Jan 2024 21:54 #253550 by 1stwee jimney
hi ive just bought my first jimney a automatic 2015 with 27000 miles being my first jimney im not aware of any running noises they might have
so my question is do they make a sort of whining noise when underway
16 Jan 2024 23:52 - 16 Jan 2024 23:53 #253551 by facade
Replied by facade on topic whine possibly from gear box
Not loudly.
The transfer box chain "sings". If someone has fitted a skid plate it reflects the sound back up into the cabin (guess how I know ;)  )
Autos do whir a little but not really loud enough to notice. The axle can whine a little, and the tyres can be quite loud.
They are not quiet cars tbh, if you are used to a luxury car with some "insulation" it may sound odd.
Maybe someone is close to you and can have a listen.
Last edit: 16 Jan 2024 23:53 by facade.
17 Jan 2024 06:17 #253554 by Lambert
Agreed they're not a Bentley for sure but the automatic is noticeably quieter than the manual mostly because the revs are lower for any given speed. Where in the world are you that one of us may be able to listen to it for you or give you a baseline in ours?
23 Jan 2024 23:21 #253715 by GandHisJimny
I've owned two automatics (05 and 07) and yes, the transmission has a certain whine or hum to it that I believe is normal. They both did / do it in the exact same way. It's not an ugly sound, I actually quite like it. Happens the second you put your foot down and stops as soon as you lift it.
The properly "bad" car sounds are normally quite overtly nasty sounding. If you're getting crunches on gear shifts or something then I'd worry about that. A light hum is fine, so long as it isn't getting worse / louder over the next e.g. 6 months.
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
28 Jan 2024 09:37 #253833 by William1299
its coming from the diffs (front and rear) and also from the transfer case, be advised there will be a chain slap noise (crunching sound) from the transfer case if u start the car on the hill, most suzuki dealer knew about this design flaw and i just try to live with the sound, although theoretically it could be an easy fix with a tensioner ?
  • rogerzilla
28 Jan 2024 11:47 #253835 by rogerzilla
Replied by rogerzilla on topic whine possibly from gear box
The manuals have a bit of a whine at 70mph, should you choose to crank one up that high.  Smooth enough, though.
Time to create page: 0.324 seconds
