Jimny boot filled with water after driving through torrential rain (pics inc!)
02 Jan 2024 19:28 #253213 by GandHisJimny
Very interesting on the alcohol content / blue colour bit! And yeah, that makes sense about the one-way valve. It failing might explain my fluid draining but not it going into the car itself. This weekend or next I'll pop the back door cover off and take a proper look to see if there's an obvious split anywhere. I was going to do it anyway to stick some sound dampening / lanoguard in there so two birds with one stone...
Big thanks again, will post if I find anything.
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
03 Jan 2024 13:24 #253222 by GandHisJimny
Investigated more today. I refilled my wiper fluid and intentionally parked on a steep hill. I could see that the wiper fluid was forming drops and leaking out the back jet (outside the car). That would suggest I have the same one-way valve failure everyone else complains about. Should be an easy fix.
But it does imply that my boot water leak is not related to wiper fluid. Not least because when I checked the car I could see a little drizzle of water in the back corner again and that appeared despite my wiper fluid being empty. Given I power washed yesterday it could be that it just took some time to seep through and it is indeed to do with the boot seal / door not closing fully. I'll muck about with it once I've got some free time.
03 Jan 2024 17:10 #253226 by DrRobin
Fluid leaking out of the washer jet to the outside is probably not the one way valve, it's designed to let fluid out, just doesn't allow reverse flow, i.e. air back in to stop the pipe from draining back in to the reservoir.
A leak from the door, window or roof is most likely and yes, it might take time to seep through and pool in the boot. If it had been leaking through the weld, you would have thought it would have been there straight away.
Robin
09 Jan 2024 14:25 #253385 by GandHisJimny
Still baffled by this. So the whole wiper fluid thing was a distraction but I've replaced the valve and I'll see if it my reservoir drains out or not. Also sound proofed both my doors and the back so woop woop.
But as for the leak, I jet washed again today and there were immediately a few small drips of water in the back driverside corner (it was bone dry before I started, hasn't rained in Glasgow for about 5 days amazingly). It was hanging out where the metal of the boot panel meets the plastic trim. So I am now minded that it must be dodgy factory seam sealing essentially where the rear wheel arch meets the bottom boot panel.
To properly investigate I'll need to take the back seats / panels out again (I seriously hate that job). I may just run a bead of tiger seal along it to remove any doubt.
09 Jan 2024 15:21 - 09 Jan 2024 15:54 #253386 by GandHisJimny
The closest thread I can find is this one by Halford ( www.bigjimny.com/index.php/forum/6-jimny...oot-floor-rust-again ) - i.e. magic drops of water appearing in the back lol.
Will drop him a message and see if he ever resolved it.
Last edit: 09 Jan 2024 15:54 by GandHisJimny.
09 Jan 2024 15:43 #253388 by Halford
never did get to the bottom of it - but maybe Kirkynut  was onto something
