Rainwater ingress - where from?
20 Dec 2023 10:48 #252955
by Mabster
Rainwater ingress - where from? was created by Mabster
Hello advice needed please. My Gen 3 2001 Jimny has sprung a leak, rainwater is trickling down the inside of car on drivers side, emerging from under the cubby hole by the rear door and puddling in the tool well. This rainwater isn’t being forced in when driving, car is stationery, so I’m assuming a seal has gone somewhere local to the puddle? I can’t see anything obvious. Roof lining above is dry. Externally the roof bar fixing onto the roof has a bit of play, is there a fixing point that might allow water in? The side rear window is well fitted and all door seals are intact. Are there any gutters or drains that may have blocked? Any thoughts please?
20 Dec 2023 13:21 #252957
Replied by jackonlyjack on topic Rainwater ingress - where from?
Take out the trim panel
Could be rusted through behind it. If it's not then put some talcum powder all over and the water ingress will show where it's travelled from
The following user(s) said Thank You: Mabster
20 Dec 2023 14:19 #252960
by Mabster
Replied by Mabster on topic Rainwater ingress - where from?
Car was subject to extensive welding a year or two ago, be surprised if that was the root but will take panel off and talcum! I was just wondering if anyone know of any obvious bungs, stoppers or channels nearby that might need maintenance before I took the trim off. Thanks again for taking time to respond.
20 Dec 2023 17:42 #252963
Rear light has a grommet behind
but i doubt water would make it's way into the boot
20 Dec 2023 23:03 #252973
by Mabster
Thank you for the grommet info. I guess it’s off with the panel and out with the talcum powder….
21 Dec 2023 00:16 #252975
by Bob1050
Replied by Bob1050 on topic Rainwater ingress - where from?
I will second the talcum powder technique. Thought for a moment that I had wandered into a Land Rover forum tonight. Solihull really know how to build cars that leak and since purchasing a Jimmy. I no longer look for puddles in the footwells. Just be aware that newly welded seams and adjacent panels are not always 100% watertight but you are doing the right thing in seeking to sort the problem before more (expensive) damage ensues.
Time to create page: 0.292 seconds
