JB74- K15B ECU wiring Pinout Diagram
19 Dec 2023 09:33 - 19 Dec 2023 11:32 #252932 by MIghty Zuk
Hi, I've been looking for the ECU wiring pinout for my K15B engine. Been searching and asking everywhere for it but no luck, would anyone have a copy of the wiring pinout diagram.
I'm currently wanting to rewire the wiring harnesses from the ECU to the transmission. Having the diagram will really help out lots. Thanks
Last edit: 19 Dec 2023 11:32 by MIghty Zuk.
19 Dec 2023 09:58 #252933 by mlines
What are you trying to achieve?
The ECU controls the Engine.
The BCU (Body Control Unit) and TCM (on A/T systems) and 4WD module control the rest of the vehicle including the transmission. However the bulk of the communication is now CANBUS so is a data link, not simple sensor signals.
The following user(s) said Thank You: MIghty Zuk
19 Dec 2023 11:32 - 19 Dec 2023 11:51 #252934 by MIghty Zuk
Hi, thanks for the info.
 I've bought a K15B engine together with the 4 speed A/T transmission but the wires has all been cut therefore I would like to figure out what each wire connects to.
Thanks !
I've attached a picture of the ECU/BCU and the cut wires.
Last edit: 19 Dec 2023 11:51 by MIghty Zuk.
19 Dec 2023 13:58 #252939 by fordem
I hate to be the bearer of bad news, but, the wiring is going to be the least of your problems - you're not going to get that running without the immobilizer & keys from the Jimny that ECM came from, or another immobilizer & key set AND a way to program them to one another.
You're also going to need the TCM, BCM and pretty much every other electronic controller the "donor" car had fitted because they're going to look for one another and generate fault codes when they can't find the missing controllers.
19 Dec 2023 14:21 #252940 by mlines
21 Dec 2023 09:21 #252983 by MIghty Zuk
HI, thank you so much for the much needed info!
I've currently managed to rewired the ECU wrings, bypass the immobilizer and the BCM connected. However i was only aware of the TCM after you mentioned it. I then went looking for one. I'll attached an image, would you kindly help me to confirm that this is the TCM for the engine. thanks you!
Time to create page: 0.178 seconds
