Very low spped 4WD-H behavior
29 Nov 2023 10:42 #252452
by Ulltand
Very low spped 4WD-H behavior was created by Ulltand
Hello!
Noticed that the car dont roll easily in very low speed whith engaged clutch/neutal i 4WD mode. Almost like breaking. Is that normal? Thanks!
29 Nov 2023 12:22 #252462
by facade
Replied by facade on topic Very low spped 4WD-H behavior
Any difference in the tyre diameters front to back, due to wear or wrong pressures will cause the transmission to wind up slightly, as will any steering input. This will be more noticeable on tarmac as the wheels can't slip a little to relieve it like they can on wet grass or mud.
Or the front axle could be partially seized.....
The following user(s) said Thank You: Ulltand
29 Nov 2023 14:24 #252470
by Ulltand
Replied by Ulltand on topic Very low spped 4WD-H behavior
Ill check tire pressure and avoid steering next time.
29 Nov 2023 14:27 #252471
Replied by mlines on topic Very low spped 4WD-H behavior
Are you trying it on tarmac or other firm surface
Time to create page: 0.257 seconds
