Slow coolant leak from hoses
  • rogerzilla
19 Nov 2023 10:16 #252216 by rogerzilla
Slow coolant leak from hoses was created by rogerzilla
I used Halfords hose clips when I replaced the top and bottom hoses.  These have been problematic - I have had several small leaks (I'm currently checking the expansion bottle weekly).  Supposedly the rubber expands a lot when hot and can stretch a metal clip beyond its elastic limit, meaning it no longer grips tightly enough to form a good seal.  The leaks occur when the engine is cold and the hose has contracted.
There is a limit to.how much I want to tighten a clip on a 12 year-old radiator stub!  It will stay watertight for a month and then start leaking again - currently from the bottom hose to radiator connection.
Any tips?  Are genuine Jubilee clips any more springy?  The original clips were too far gone, and hard to fit in situ anyway.
19 Nov 2023 10:29 #252217 by Scimike
You haven't said if the hoses are old or new.
I had a similar issue with the top hose, couldn't get it to seal. Eventually I order a new top hose and it was obvious the original had expanded over time, it was the elasticity of the hose causing the issue.
  • rogerzilla
19 Nov 2023 10:42 - 19 Nov 2023 10:43 #252218 by rogerzilla
Replied by rogerzilla on topic Slow coolant leak from hoses
New genuine Suzuki hoses.  They are fully pushed onto the stubs and the clips are correctly behind the lip of the stub.  They seal for a while then leak again.
Nee OEM spring clips might be better but would involve another full drain, and they are horrible to use on the bottom hose!
Last edit: 19 Nov 2023 10:43 by rogerzilla.
19 Nov 2023 12:39 - 19 Nov 2023 12:43 #252220 by Scimike
Ok that's good.
Jubilee clips are ok providing you get the correct size, the issue with them is the screw assembly radius. Irrespective of what size they say the are for, unless the curve on the inside of the screw assembly matches that of the pipe to be clamped perfectly, they can distort the pipe in this area. This results in uneven clamping pressure and leaks.
The Suzuki OEM spring clamps don't do this, they even compensate for expansion / movement in the pipe, providing even clamp pressure all around.
They are much better, swap to these. But even these may struggle if replacing jubilee clips that have been tightened too much in an attempt to stop leaks, they crush the hose removing all chance of a seal in that area.
Just my opinion
Mike
Last edit: 19 Nov 2023 12:43 by Scimike.
  • rogerzilla
21 Nov 2023 21:12 - 21 Nov 2023 21:12 #252283 by rogerzilla
I've ordered two new hoses (again), the factory style clamps and another 5 litres of coolant.  This has been totally successful because the car has already decided to stop leaking of its own accord.  The level hasn't dropped at all since I last topped it up to the line.  It knows.
Seriously, I think very cold weather will allow it to seep again as the stretched jubilee clips don't contract with the hose.
Last edit: 21 Nov 2023 21:12 by rogerzilla.
21 Nov 2023 21:49 #252284 by Scimike
They do indeed know
Well, if it's fixed who cares. Of course "never touch a runner" is probably applicable a this point, so bung the bits on the shelf.
Time to create page: 0.158 seconds
