4wd system
17 Nov 2023 07:40 #252165
by Stalker
4wd system was created by Stalker
My 4WD system does not work and a Suzuki garage who came well recommended have told me it is uneconommic to repair. I have looked at YouTube videos about rebuilding the ends of the axels etc and it looks straight forward so I am unsure what the problem is but if they are correct will fitting a pair of manual free wheeling hubs restore the car to 4wd?
Any advice welcome and appreciated.
- Thank you received: 2004
17 Nov 2023 08:08 #252166
Replied by Lambert on topic 4wd system
If they're wanting to replace all of the factory hard vacuum lines etc then yes it will get expensive using factory parts. This assuming that the vacuum system is actually at fault. Other than that 4x4 not working and a garage telling you it's going to be expensive what are your actual symptoms and what if anything have you done in the way of diagnosis? There's a comprehensive trouble shooting guide in the information section at the top of the site to read through. But certainly there are always options to keep it going in a wallet friendly manner.
- rogerzilla
17 Nov 2023 08:57 #252167
by rogerzilla
Replied by rogerzilla on topic 4wd system
There are numerous points of failure but things like the vacuum lines across the front axle - which rust merrily - apparently require genuine (expensive) Suzuki parts as they are not the same size as brake piping. If the hubs aren't sufficiently airtight they can also require a total rebuild.
Basically, it is hard to narrow down the problem so most people plug the vacuum lines under the battery box and fit manual locking hubs. The loss of convenience is not huge, as it is no real issue to drive in 2WD with the hubs locked if your journey varies between slippy and grippy surfaces.
17 Nov 2023 14:40 #252169
Replied by yakuza on topic 4wd system
i am quite sure that i should get it to work with other near same dimension pipes and hoses as long as it is approx the same volume and air tight. Cant see why not.
I like the vacuum hubs and do not miss having to dive into the mud or snow to engage the manual hubs on my SJ.
I am not put together so that I would remember to engage them before the need would occur more than once every leap year.
17 Nov 2023 15:03 #252170
by Phaeton
Replied by Phaeton on topic 4wd system
I read somewhere else it was 8mm pipe, screwfix do an 8mm copper pipe, no idea if it's suitable or not, but it might be with an investigation, I use it on my kitcar as fuel line.
- Thank you received: 679
17 Nov 2023 15:59 #252173
Replied by DrRobin on topic 4wd system
I think (from memory) it is 4mm internal diameter pipe. My vacuum lines became blocked last year and after wasting hours trying to free them off I bought manual hubs and have never looked back.
Suzuki's arrangement of metal pipes and several flexible sections is horrible and I was going to get some lengths of coloured pipe, then put the T-piece at the top and run a separate pipe for lock/unlock to each hub in the summer so I could go back to vac hubs, but just didn't get round to it.
The pipe is very easy/cheap to get on eBay.
Robin
Robin
Time to create page: 0.088 seconds
