4x4 not working, with manual hubs
12 Nov 2023 09:11 - 12 Nov 2023 11:14 #252082 by Ht03
Sorry to sound completely useless but it’s baffling me. The transfer box I assume still works as low box still engages. I don’t think it’s the diff as I can’t spin the front prop when in 4wd and I can when in 2.
I have manual hubs too, recently I rebuilt the axles but I took these off in the two parts. Didn’t actually interfere with the internals of them so can’t see where I would’ve got that wrong. No unusual noises either.
Any ideas please before I start crawling round in the wet outside, Cheers
Last edit: 12 Nov 2023 11:14 by Ht03.
12 Nov 2023 09:32 #252083 by DrRobin
Is manual lockers, manual hubs?
The hubs might be sticking, you could take one off and see if the shaft locks in place in 4WD? If it doesn’t it suggests the diff?
If they are still vacuum hubs then you might have a blockage in a vac line or again the hubs are sticking.
Robin
12 Nov 2023 09:34 #252084 by DrRobin
Forgot to mention the front prop is locked by the transfer box, rear prop and rear wheels when in 4wd.
12 Nov 2023 09:43 #252085 by Ht03
Replied by Ht03 on topic 4x4 not working, with lockers.
Cheers, yes I meant manual hubs sorry. And I will try taking them off and checking. Thankyou
12 Nov 2023 10:30 #252086 by Lambert
Assuming you have AVM ones when you twist them in and then get back into the car and engage 4x4 and pull forward within a couple of rotation of the wheels you should hear a definite click from each one as the springs engage the drive members. This will obviously be clearer with a window open. It is possible to check by lifting one front wheel while in 4x4 and spinning it, with the hub in it shouldn't rotate or if it does it's something deeper.
12 Nov 2023 13:01 #252087 by fordem
What makes you think it's not working?  What are the symptoms?
