Tyres
22 Sep 2023 17:55 #250968 by Stalker
Replied by Stalker on topic Tyres
Thank you all for helpful advice, the vehicle is going for a check up next week but when I was stuck both front and back wheels were spinning on the same side of the vehicle so I assumed 4WD was working.
Interestingly most of you are advocating a higher profile than the existing tyre ie.215/75 rather than 205/70. Is there enough space under the wheel arches to accommodate the larger profile?
22 Sep 2023 18:38 #250970 by DrRobin
Replied by DrRobin on topic Tyres
It’s not that we advocate 215/75, it’s just BFG and Maxxis are not available in 205/70.
215/75 is the largest tyre you can fit without a lift or trimming of the wheel arch.
It raises the earring by about 4%, so your speedo will read about 4% lower. Not usually a problem as they all over read by about 5-10%.
The wider tyre should give more grip on some surfaces and combined with the chunky tread pattern in my opinion definitely looks the part, especially if you get a tyre with white lettering.
I have two sets of alloys one set fitted with Maxxis Worm-Drive 215/75 and the second set with Hankook Dynapro 205/70. I intended to put the Dynapro on in summer and the Maxxis in winter, but the summer was so wet and to be honest on the road there isn’t much difference I have just stuck with the Maxxis this year.
Robin
22 Sep 2023 20:29 - 22 Sep 2023 20:32 #250973 by 300bhpton
Replied by 300bhpton on topic Tyres
ok, so if your 4wd is working it then comes down to driving technique and maybe some mud terrains.
Wet grass can be some of the most slippery conditions in off roading. What sort of soil is it on? Are you in the UK?
In most cases you'll need some momentum to get up steep slippery slopes. No idea on your experience, but might be worth getting some additional tuition if you are new to off roading.
How much road driving do you do? And are road manners and mpg a concern here?
I have the Maxxis Wormdrives and have been impressed with them. But the traction control on the 4th gen helps quite a bit. They are still not on par with a good mud terrain. So I'm impressed for my road going Jimny, but probably wouldn't be what I'd pick for proper off roading.
Mud terrains come in a couple of different varieties. Many Mud terrains are nothing more than aggressive all terrains. While some are much better. Then you have the more extreme off road tyres which will be the best on slippery muddy grass.
I'd rate the BFG MT KM3 as one of the best 'new' mud terrain patterns. And I'd rank them a cut above most other MT's although these look like they should be capable:
tyresdirectuk.co.uk/products/205-70r15-9...a3200-owl?taxon_id=8
tyresdirectuk.co.uk/products/215-75r15-1...-m-t-g003?taxon_id=8
And would be a rung up from your AT's while still being quite acceptable on road. Also a lot cheaper than the BFG's.
If you want more off road performance you need to look at remould tyres. Depending on the tread they should still be ok on road, but more noise, less mpg and generally not so good on road.
tyresdirectuk.co.uk/products/205-80r16-9...bo-sahara?taxon_id=8
tyresdirectuk.co.uk/products/215-75r15-1...o-sahara?taxon_id=74
This tread is surprisingly versatile and will work well everywhere and be better on road than they have any right to be. Either the KM3 or these would probably be my choice depending on how much you want to spend.
If you want even more extreme you have these:
tyresdirectuk.co.uk/products/205-70r15-9...l-track-2?taxon_id=8
These can be very good off road, but generally way worse on road than the ones I listed above. I'd only go for these for a play vehicle or a competition trials vehicle.
Last edit: 22 Sep 2023 20:32 by 300bhpton.
  • rogerzilla
  • Visitor
  • Visitor
23 Sep 2023 10:19 #250978 by rogerzilla
Replied by rogerzilla on topic Tyres
You were just unlucky there.  Both front and rear differentials are open (i.e. not limited-slip or lockable) and simply divide the torque in two.  Therefore if one wheel has no grip, very little torque is needed to keep it spinning and that means the other wheel on the axle gets very little torque too.
4WD mode halves the chance of this happening, because there is no centre diff in a Jimny and therefore both a front and a rear wheel need to have very low grip for it to be stuck.  If tyres alone can't do it, you'd need locking diffs or LSDs to really minimise the chances.
Time to create page: 0.150 seconds
