High Mileage 2006 Jimny
25 Aug 2023 11:23 - 25 Aug 2023 11:31 #250501
by facade
Replied by facade on topic High Mileage 2006 Jimny
I actually traded it in because I reckoned it had at most another MOT in it before it needed welding. Under the headlights and around the rear bumper body mounts were going. The Dinitrol had done a good job holding it back for 10 years.
The current MOT has flagged corrosion at the rear, I wouldn't be surprised if I don't see it next year, but I suppose the high value is worth £500 on welding.
It was the desirable model, the first of the M series engines, cheap tax (on an X plate- the massive hike for emissions came in for Y) and had the proper split folding rear seats.
It was much better appointed inside than the Gen4 too, no bare metal showing, comfy seats (and that split fold), non slippy seat backs/ boot floor and a proper temperature gauge
(I traded it as it wasn't worth dealing with all the timewasters & chancers, and then have someone bring it back complaining about some "fault" for about £150 more by the time they'd knocked me down to £1000)
Last edit: 25 Aug 2023 11:31 by facade.
- GandHisJimny
- Premium Member
- Thank you received: 14
25 Aug 2023 13:34 #250510
by GandHisJimny
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
Replied by GandHisJimny on topic High Mileage 2006 Jimny
I paid £3,800 for a 50k miles 2005 VVT automatic earlier this year. The exterior bodywork was all great and it had recently passed an MOT. No AC (standard JLX edition?) and the rear interior plastics had some gouges from presumably previous owner's dog but whatever.
I thought I got a reasonable deal but after getting it home and taking a proper look (removing interior panels, getting pokey with a screwdriver) I realised the rear arches and boot panel were pretty badly rusted and would definitely need doing unless Stevie Wonder was available for another MOT. I have now paid thousands on getting it repaired and lanoguard'd which has turned what seemed a good deal into a pretty meh one but at least it is done.
That said, used Jimmers go for serious amounts even in spite of being rust buckets. You'll see them semi-regularly in "top 10 cars for retaining value" type lists and indeed I think the Gen 4 demand has overflowed into the Gen 3 used market. The cheapest automatic VVT / facelift Jimny in the UK right now on Autotrader is listed at £5,500 and that's a 2008 with 92k miles. Dealers have them listed at like £8k+ which is bananas. That's for automatics though which command as much as a 50% premium because they're less common.
For you? I wouldn't overthink it and frankly 131k miles isn't outrageous. If the corrosion is minimal then consider yourself blessed. No backsies now - welcome to the club!
25 Aug 2023 17:32 - 25 Aug 2023 17:41 #250518
by oldgazzer
Replied by oldgazzer on topic High Mileage 2006 Jimny
I tried my best to check for rust before purchasing. Fingers crossed I have been fortunate. I have removed the rear seats and no signs of any rust on the floor panels. It was up on ramps having a new exhaust and I had a good look round and apart from a bit of surface rust all looked good.
I was a fabricator/welder many years ago, so if needs be I could do some welding on it.
When I was looking for a Jimny before buying mine someone was advertising an auto Gen 3 Jimny on Gumtree with very low mileage (under 40,000). I messaged the person who told me it was her mothers car and had been used for pottering about town. Unfortunately I was slow off the mark and it went within hours of being advertised. It was being advertised for £4,000 ono.
Last edit: 25 Aug 2023 17:41 by oldgazzer. Reason: Layout change.
- rogerzilla
26 Aug 2023 07:15 #250523
by rogerzilla
Replied by rogerzilla on topic High Mileage 2006 Jimny
We've just paid £11.5k for a 2012 auto with 49k on the clock. Silly money for an old car - could have had a 2019 Renault Zoe, which is auto by default! - but a bit underpriced for a Jimny now. MOT history has no advisories on corrosion, which is unusual. There is a bit of rust behind the headlights, which seems otherwise solid, but the boot floor and underneath looks quite nice (I don't think many car dealers expect buyers to spend half an hour underneath with a torch!).
26 Aug 2023 12:08 #250528
by Busta
Replied by Busta on topic High Mileage 2006 Jimny
Condition is far more important than mileage. The M series engines will do over 150,000 with minimal servicing. The earlier G series may need a head gasket before then, but are otherwise solid.
I've seen a 60,000, mile, 12 year old Jimny still on the orginal set of tyres and the body was completely rotten!
- GandHisJimny
- Premium Member
31 Aug 2023 08:29 #250592
by GandHisJimny
Yep, and per above M series engines that OP has got are timing chain driven - not belt as the earlier G models are - so much less of a worry there.
