Gen 3 Auto box pipes - does anyone replace them?
  • rogerzilla
20 Aug 2023 19:04 #250405 by rogerzilla
These are on the service schedule (according to Car Mechanics' Oct 2014 servicing guide) but do they really need to be changed? Is it difficult?
Thanks.
20 Aug 2023 19:49 #250409 by fordem
Are you referring to the "cooler" pipes that run between the auto transmission and the heat exchanger in the radiator?
I've never heard of these being a "scheduled replacement" item on any vehicle, I want to suggest you check the service schedules in your owner's manual for guidance on replacement. There may be a scheduled "inspection", but I doubt it's a scheduled replacement - I don't have a manual for a Gen3, I checked my Gen4 and that says inspect for the hoses, not the pipes.
Replacement - replacing the hoses is what I would consider easy, but please bear in mind, I don't know your "skill set", two hoses secured by spring clips, do it with the engine/transmission cold, have some old newspaper handy to mop up the spilt transmission fluid (it's not going to be a lot) and a liter of fluid to top it up, you'll have most of the liter left over.
If the pipes need changing that will be a different matter, accessibility is where the challenge will lie.
Personally, I'd say if they are not leaking and don't look corroded (the metal pipes), leave them be, just check the fluid level at regular intervals as you would the engine oil & coolant.
Transmission fluid levels need to be checked with the transmission warm and the engine running, shift through all the gears with your foot on the brake, from park all the way to low pausing for a few seconds in each position, then back to park and check with the engine idling.
  • rogerzilla
21 Aug 2023 05:59 #250421 by rogerzilla
Replied by rogerzilla on topic Gen 3 Auto box pipes - does anyone replace them?
Thanks for the reply - yes, these seem to be the only pipes there are from the autobox. I'll have a good look at them but it's only a 61 plate so they should be ok. I have changed lots of hoses (coolant and brake) before on other cars, although it's not my favourite job.
Time to create page: 0.067 seconds
