AC fan override?
20 Aug 2023 17:46 #250404 by Lambert
AC fan override? was created by Lambert
The AC's electric fan is controlled by the operation of the cab switch and meeting the airflow needs of the condenser fair enough. However one of the side effects is that when working hard at low speed with a trailer switching the AC on pushes air over the transmission cooler and helps keep the temperature around 110c but at the expense of running the AC pump with the associated losses in power and fuel consumption.
So before I get busy with the multi meter and install a relay and switch for manual control of just the fan is there anything I should be aware of or is it just a case of power and go.
20 Aug 2023 21:57 #250420 by fordem
Replied by fordem on topic AC fan override?
I have only one concern about this, and it's the possibility of accidentally leaving the fan running after the engine has been switched off - it should be possible to rig a second relay with the contacts in parallel with the existing relay and power that relay from an ignition source so switching the ignition off switches the relay off.
Years ago I did something similar on a transverse engined Simca wagon that had an electric fan, in slow moving traffic the coolant temperature would rise until the fan cycled on, the temperature would then fall until the fan cycled off and this would repeat - it was the way the system was designed to work, but I found it irritating.
I installed a "bypass" switch that turned the fan on manually and would flip that switch when I encountered slow moving traffic - there's no real chance of "over cooling" things as the thermostat is there to maintain the engine coolant temperature.
21 Aug 2023 08:18 #250427 by LesNewell
Replied by LesNewell on topic AC fan override?
If you use a relay in parallel with the existing relay you should have no problem. I'd recommend powering your switch from an ignition feed so you can't accidentally leave the fan running. Admittedly it's pretty obvious if you leave it on, the fan isn't exactly silent.
Just be careful to use a big enough relay and fan wiring. Fans can pull quite a bit of power.
21 Aug 2023 20:18 #250439 by Busta
Replied by Busta on topic AC fan override?
I wonder if the simplest thing would be to interupt power to the AC compressor clutch, so rather than turning on the fan independently of the air conditioning, you are instead turning off the compressor? This could be as simple as 2 wires and a switch.
21 Aug 2023 20:37 #250440 by fordem
Hmmm - interesting approach - the a/c control relays are actually driven by the ECU, turning the a/c on causes the ECU to "bump" the idle to compensate for the additional load, disabling the compressor would theoretically remove that load causing an increase in idle speed, bypassing the fan relay would increase the electrical load without the ECU being aware of it, so that would theoretically cause a drop in idle speed - neither situation would/should cause a problem in the long term, and have a slightly high idle might be preferable to a slightly low one.
22 Aug 2023 03:32 - 22 Aug 2023 03:40 #250441 by Lambert
Replied by Lambert on topic AC fan override?
So you are saying to just interrupt the feed tó the magnetic clutch, would that guarantee that the fan would run permanently on the dash switch though?
Just thinking about it then either way is going to carry a potential for the ECU to be aware that something is not right either the load on the engine is gone at idle or the fan is showing voltage when it shouldn't either of which might give a fault? I will have a look with the power probe at the weekend and see which makes it least unhappy. That said SZ viewer doesn't read HVAC systems on mine so it may just be a logic controller rather than a feedback one?
Last edit: 22 Aug 2023 03:40 by Lambert. Reason: Clarity
Time to create page: 0.149 seconds
