Re:Newbie buying Jimny
17 Aug 2023 23:48 #250341 by scoobienorth
Hello.  I’m from Canada, and have been lurking and reading from time to time.  I’m getting ready to import a Jimny to Canada.  It needs to be at least 15 years old and I’ll be pulling one from Japan. I think I know what I want , but before I start looking I want to make sure it’ll fit what I want to do.  It’ll be sitting on 30-32” tires, skinny and easily available options.  I have some sand dunes area near me, but also mud, muskeg and snow, that’s why the relatively large tire.  I know I’m pushing the limits of the diff at this tire size and available gearing. I’ve been wheeling nearly 20 years and am quite capable of building rigs, and wheel offset , body work etc to set it up.  I know I want a 1.3 and not the kie version 660cc.  I’d prefer a manual, as I can teach my daughter to drive a standard. But not tied to it.  I wanted a newer one 05+ but the manual trans is weaker?  The older body style 95-98 coil sprung ones are cheaper for me to compliance and get on the road, but I’d prefer a newer one I think. I’m not up on axles, gearing and transmission stuff. Which ones are the strongest and with the best for building? Please correct me if I’m wrong.  But I’m thinking 1: 99-04 manual 1.3L, 2:  -05+ auto 3: 96-98 1.3 manual trans    Am I missing something major? I know I’ll be lifting a bit, dealing with major tire clearance issues, gearing with tcase gears first off and probably as deep as possible.
18 Aug 2023 04:38 #250342 by Lambert
Replied by Lambert on topic Newbie buying Jimny
So for what you are planning I would offer the following. Regardless of being from Japan the older ones are going to be more prone to needing some help with rust repair. The coil spring SJ I don't know enough about other than they exist and look cool. The pre 05 manual is definitely a good option. The post 05 manual is not weaker as such it's just that the design included bearings that were meant to be splash lubricated but this didn't happen effectively, they are rebuilt with sealed versions however and that solves it. The automatic is generally very reliable on the back of the stock motor but they specified it with only a few more Nm capacity than the engine produces. Not a big problem and additional heat management is going to help in severe use.
With regards to running bigger than 30's you will definitely need a transfer reduction set with any gearbox. You are also probably going to be thinking about trussing the axle cases. The automatic is generally going to be kinder to the shafts and CV joints than the manual but if you are bouncing around or regularly lifting a wheel and letting it spin then grab obviously it's going to snap something. You can get very expensive heavy duty shafts and CV joints but at several times the cost of standard ones the value for money is debatable. Running in mud, silt and sand it is going to render all axle bearings as service items with a similar life as the motor oil and filter so around 6 to 9 thousand miles through when combined with the bigger tyres this will only get shorter. At which point it's going to be worth considering the floating rear axle conversion as it means all the wheel bearings are the same and easier to change, I would probably do the rear disc brakes conversion too to add more reliability. Other than that and the obvious stuff like recovery points and maybe a winch you should be good to go. As for which car, the cleanest lower milage one you can get.
The following user(s) said Thank You: scoobienorth
18 Aug 2023 06:09 #250343 by mlines
Replied by mlines on topic Re:Newbie buying Jimny
People I have spoken to had issues getting headlamps with DoT markings.
The later models which we call "Gen3" has shaped headlamps and don't have DoT markings as they were not sold in those markets. The earlier "gen2" models have 7" round lights which are widely available. The cross over models (gen2 with coil springs) have round lights
Sent from my motorola edge 40 neo using Tapatalk
18 Aug 2023 06:59 #250346 by saxj
Replied by saxj on topic Re:Newbie buying Jimny
If you're importing from Japan, I doubt you're going to find a 1300. For the kind of wheeling you are talking about, the 660cc isn't going to cope.
18 Aug 2023 09:08 #250348 by 300bhpton
Replied by 300bhpton on topic Newbie buying Jimny
What size tyres are you planning on? Not much in the way of skinny tyres these days?
I'd have thought 32" tyres would be way too big for vehicle and engine. If you plan to heavily mod and replace the engine, drivetrain and axles, fair enough. But you then have to wonder if starting with a Jimny is worthwhile if you are going to bin almost all of it.
I'm all for modding vehicles. But watching YT videos of most of the modded N.American vehicles, I'd have thought the Jimny was unsuitable.
If you want a Jimny for being a Jimny, well thats a different matter.
18 Aug 2023 11:55 #250350 by Lambert
Jack has 7.50 16s on his trials truck which are about 32 and that is still mostly a Jimny and a very competitive one at that.
Time to create page: 0.227 seconds
