Warning: Undefined variable $end_tag_params in /mnt/Main_Volume_2/www/bigjimny.com/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
Jimny 5 doors have vented front discs
12 Aug 2023 09:22 #250245 by gv42
Jimny 5 doors have vented front discs was created by gv42
Noticed this on a video of the new 5 door jimny, bleed nippe is at the top
Sent from my SM-S918B using Tapatalk
The following user(s) said Thank You: mlines
12 Aug 2023 12:59 #250248 by fordem
Replied by fordem on topic Jimny 5 doors have vented front discs
autocatalogarchive.com/wp-content/upload...y-5-Door-2023-IN.pdf
Here's the brochure - the "features" may vary from market to market, but the "specifications" should remain across the board.
13 Aug 2023 12:02 #250264 by Roger Fairclough
Replied by Roger Fairclough on topic Jimny 5 doors have vented front discs
I have a question. If the cross sectional area of the piston in the caliper that appears to be used in the vented disc conversion available through Big Jimny is larger than standard, then surely the standard master cylinder piston stroke will need to increase to flow the greater amount of fluid required to fill the caliper cylinder. In other words, brake pedal travel will increase.
Is this correct?
Roger
13 Aug 2023 12:18 #250265 by fordem
The theory is correct, and according to my notes the 1.3 Jimny piston is a 51 mm diameter, and the Vitara piston is a 54mm, as is the piston from the 1.5 diesel Jimny.
Suzuki chose to use the same brake master on both models of the Jimny so it would appear that the increase in pedal travel is "within acceptable limits".
I've done a similar brake swap before on a Suzuki Swift, the increase in pedal travel was noticeable but not excessive, I hunted down part numbers and specs for the Jimny upgrade, but so far I haven't needed it.
13 Aug 2023 15:25 #250275 by Roger Fairclough
Thank you fordem, it's always nice to get confirmation. With the bore sizes you have given me, I might be able to get an idea of the increased travel I might expect.
Unless someone has already done the maths?
Roger
