Re:Gearbox rear seal replacement
06 Jun 2023 14:41 #249439 by me101
Hi, Little Jim is currently rust proofing the underside. Seems to be leaking from the rear of the gearbox, where the shaft goes in. Would I be correct in thinking this should be just a case of remove the shaft, replace a seal, and all good?
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
06 Jun 2023 16:10 - 06 Jun 2023 16:11 #249441 by jackonlyjack
Yes it's a bit of a faff getting old one out
I put new in with a socket  on an extension bar tapped home with hammer
Just make sure if you're not draining oil to reverse up some ramps
This will keep oil level below the seal
Last edit: 06 Jun 2023 16:11 by jackonlyjack.
06 Jun 2023 16:33 #249442 by me101
Replied by me101 on topic Gearbox rear seal replacement
I bought a seal puller when doing rear wheel bearing, so hope that works. I did think about not draining oil, good point.
06 Jun 2023 17:05 #249443 by mlines
It's quite often a leak in UJ yoke. You will see a pressed cap in the middle of the joint, oil leaks from here. Clean it and epoxy it in place
Sent from my moto g42 using Tapatalk
07 Jun 2023 06:34 #249446 by me101
Thanks, Will have a look at the UJ.
Time to create page: 0.136 seconds
