Re:Towbar bike rack recommendations?
- GinnieB
22 May 2023 13:40 #249219
by GinnieB
Towbar bike rack recommendations? was created by GinnieB
I'm getting a towbar* fitted to my Gen 3 Jimny, and am after some recommendations for a 2-bike rack to for it. Any recommendations of brands/models?
*thanks for the article on this, Big Jimny!
23 May 2023 07:22 #249235
by Scimike
Replied by Scimike on topic Towbar bike rack recommendations?
How far the towbar protrudes and it's type (Swan neck or traditional) will impact which will work on your Jimny.
So which type are you having fitted and do you have the spare mounted on the back door?
It's all about clearing the spare, some vertical bar type mounts may hit the spare depending upon how far the towbar mount point protrudes.
So for any recommendations check all things are the same.
I have a Thule 3 bike that I've had on all my cars. But even with a Witter removable swan neck (it protrudes a lot) it just fouls the spare, so to use it on the Jimmy I have to remove the spare.
23 May 2023 08:45 #249238
by facade
Replied by facade on topic Towbar bike rack recommendations?
I also have a Thule "3 bike" (in their dreams, no way can I get 3 adult 'bikes on it) and with the standard shin bruising hitch on the gen 3 I could only get one bike on it because of the spare wheel. And the 'bike sticks out far enough past the car that I worry about hitting something.
I solved the problem by getting collapsible bikes that go in the back. You can get even folding mountain bikes nowadays.
- GinnieB
23 May 2023 12:38 - 23 May 2023 12:41 #249242
by GinnieB
Replied by GinnieB on topic Towbar bike rack recommendations?
Thanks for this - according to the garage fitting the towbar, they cannot stick out too far as they become less able to support weight the more they protrude (which makes sense). So I may have to remove the spare when using the bike rack as you suggest, which I'm happy to do!
Last edit: 23 May 2023 12:41 by GinnieB.
- GinnieB
23 May 2023 12:41 #249243
by GinnieB
Thanks - great advice!
23 May 2023 19:10 #249247
by Zaskar97
Replied by Zaskar97 on topic Towbar bike rack recommendations?
On my gen 3 I have the Brink detachable tow bar, which clears the door mounted spare wheel. I have the Thule velo compact 3 bike carrier and it fits just right.
The following user(s) said Thank You: GinnieB
