Aftermarket alarm systems?
22 May 2023 07:30 - 22 May 2023 07:31 #249215 by GinnieB
Any advice on an aftermarket alarm system for a Gen 3 Jimny? I looked on the Halfords website and the Gen 3 model didn't come up! Don't want to spend a huge amount of money as the car is parked on a private drive, but want to make it as hard as possibl for thieves (I've just installed a Trutrack GPS tracker ). Many thanks!!
Last edit: 22 May 2023 07:31 by GinnieB.
22 May 2023 11:20 #249216 by Lambert
Replied by Lambert on topic Aftermarket alarm systems?
I get where you are coming from but these days if they want it then they just go for the keys either physically or with a spoofing device. At least with a tracking system you know where it is to direct the police. I also have a steering wheel lock just to make the opportunist look elsewhere.
22 May 2023 11:22 #249217 by Lambert
Also it's a matter of being able to demonstrate to the insurance that some effort was made to minimise the risk.
The following user(s) said Thank You: GinnieB
22 May 2023 13:32 #249218 by GinnieB
Replied by GinnieB on topic Aftermarket alarm systems?
Thanks for the advice. I'm getting a tracker today and have just ordered a steering lock!
22 May 2023 13:40 #249220 by DrRobin
Replied by DrRobin on topic Aftermarket alarm systems?
I used to fit an after-market car alarm to all my vehicles which didn't have one, go for a Thatcham approved model, it will be about £50-£100 if you fit it yourself.
However, the problem with an alarm is will it stop someone from having a go (no) and if they set the alarm off will they continue to try and steal the vehicle (yes), this is based on experience with other makes of car.
If your alarm goes off at 2am on a dark winter's night are you prepared to get dressed and go outside to confront whoever might be there, given it might not even be safe or wise to do so?
Your tracker is a much better idea, however, if the thief knows it is there he will only disable it before you can get chance to use it.
If it is parked on a drive, get some gates and lock them, that way a thief might not even bother looking at your car. Or get a security camera fitted to the house pointing at the car, that way you might get a video of the thief stealing the car.
Robin
22 May 2023 18:08 - 22 May 2023 18:15 #249223 by Scimike
Replied by Scimike on topic Aftermarket alarm systems?
I also favour a visible approach, disklok is the type to go for if you have the cash. This can be enough to make them look at someone else's car rather than yours. The standard immobiliser should slow them down, the forum is certainly unable to get around it
Park sensible and don't have any valuables on show, commonsense helps.
I have a trutrack or two fitted to some of my vehicles, works well. I use the geo fencing feature to make safe places. If the vehicle moves out of this area or is even started I get a txt and email alert. You can then track if you wish or inform the police via trutrack. Hide the thing though, don't just glue it to the battery as they suggest.
Yes all these devices can be defeated given enough time, but time is the enemy of thieves. Do nothing and they drive away in seconds.
Last edit: 22 May 2023 18:15 by Scimike.
Time to create page: 0.354 seconds
