Idler Bearing on Power Steering Pump
03 May 2023 11:56 #248938 by maverick
Does anyone know if you can change the "Idler Bearing" on 2004 Jimny Power Steering Pump?
Jalapeño, IISY?
03 May 2023 12:18 #248939 by Busta
Yes you can. Just press the middle out and back into the new bearing.
The following user(s) said Thank You: maverick
03 May 2023 17:42 - 03 May 2023 17:47 #248942 by Scimike
If its the same across the years then SKF6010-2RS1 is a starting reference, but you press the inner and outer to replace with this (2009 model). I believe it's 50x80x16 size.
You can also get the complete item as a universal assembly, I have the part reference if that's the way you want to go rather than OEM Suzuki. That's what I fitted, but looked into alternative (cheaper cost) bearings.
Last edit: 03 May 2023 17:47 by Scimike.
04 May 2023 10:48 - 04 May 2023 10:52 #248954 by facade
As Scimike says, on the M13 the pulley is an assembly.
The centre (50mm OD) presses out and the bearing presses out of the outer metal "tyre" (80mm ID), so if yours is rusted away you need a new assembly.
Suzuki want hundreds for one, but there are aftermarket ones for about £60 and a decent bearing is around £30 with the trouble of pressing it in & getting the old one out.
Likely you can throw the metal shields away if you use a sealed bearing
Take a look at this video from 1:50, it shows you what you are dealing with.
If you are sourcing the bearing, watch the speed rating, it goes faster than the crank pulley, by the ratio of the diameters, I'd guess it will get to 8000RPM or so if you redline the engine.
Last edit: 04 May 2023 10:52 by facade.
Time to create page: 0.219 seconds
