vitara fwh on a jimny
- Thank you received: 663
01 May 2023 12:41 #248901
vitara fwh on a jimny was created by jackonlyjack
Anyone have vitara free wheel hubs fitted with the spacer
on their Jimny and willing to post a picture for me please
I want to see how far they stick out from the hub
01 May 2023 12:47 #248902
Replied by jackonlyjack on topic vitara fwh on a jimny
This style
You may ask why............
You can take these on/off without having to split them to get to the bolt heads
- Thank you received: 1814
01 May 2023 13:36 #248905
Replied by Lambert on topic vitara fwh on a jimny
I take it that other than the protrusion they ought to fit fine? If so then I like the idea, simple and reliable.
01 May 2023 13:47 #248906
Yes they fit fine Lambert
jimnybits sell them with spacer ring
but it's all down to protrusion
I have a set of fixed sj hubs and spacer ring
but not completely liking idea of everything spinning all the time
Plus will all know to well about splitting with those tiny torx bolts
- Thank you received: 493
01 May 2023 15:44 #248910
Replied by DrRobin on topic vitara fwh on a jimny
As me and Lambert found out you can just get an Allen key down the side of the split hubs and get the bolts out when one of my Torx bolts was well and truly stuck and had to be drilled out in the vertical drill. It would be even easier if we had a ball ended Allen key or better still a long socketed ball ended Allen key.
Robin
Robin
01 May 2023 16:47 - 01 May 2023 16:48 #248914
Replied by mlines on topic vitara fwh on a jimny
Last edit: 01 May 2023 16:48 by mlines.
The following user(s) said Thank You: jackonlyjack
Time to create page: 0.162 seconds
