Jimny in Canada
24 Apr 2023 01:29 #248808
by Skaguy
Jimny in Canada was created by Skaguy
I brought my 2007 Jimny Sierra to Canada at the end of last year but hadn’t had a chance to see how she how she handled on our gravel roads. I took her out today and she got me there and back but she was really twitchy when driving over potholed sections. Have other drivers noticed this? I have an OME lift kit on order and the OEM shocks are kinda tired so I hope she’ll improve when the kit’s installed.
pic for attention
pic for attention
- Thank you received: 2001
24 Apr 2023 04:22 #248809
Replied by Lambert on topic Jimny in Canada
I guess the most obvious question is did you have it in 4x4? We don't have the vast runs of unsealed roads you in the New World do but on the odd mile of farm track I have regular access to being in 4x4 makes a noticeable difference in directional stability and so does having suitable pressure in the tyres 23 all round seemed best on my last Jimny without the tpms.
The following user(s) said Thank You: Skaguy
24 Apr 2023 04:48 #248810
by Skaguy
Replied by Skaguy on topic Jimny in Canada
Good question. It wasn’t in 4x4, I’ll try that next time and see if it helps. The reason I stayed in 2wd was that it didn’t seem necessary, it wasn’t steep or super rough.
- Thank you received: 673
24 Apr 2023 09:58 #248813
Replied by DrRobin on topic Jimny in Canada
I found the steering very light on my Gen 3 so fitted a steering damper, that made a huge difference to stability above 30 - 40mph, but that was on tarmac roads, not the rough stuff.
Tyre pattern, shocks and dampers all play their part in controlling stability especially over pot holes and then bushes, wear on the Kingpins and other linkages will all play their part.
New shocks will propable make a big difference, but if there is any wear in other components lifting it might make it worse again.
Robin
Robin
25 Apr 2023 14:20 #248835
by fordem
What vehicle do you normally drive - or - to ask the same question in a different way - how familiar are you with the handling of a short wheel base, live axle vehicle?
For people who spend most of their time behind the wheel in longer, larger vehicles, especially more modern vehicles with independent suspension, transitioning to a short wheel based, live axled vehicle, such as a Jimny, can be a rude awakening, on anything but the smoothest of surfaces, they can be unpredictable, and "twitchy" is a good description of that.
Because they are live axled, any pot hole, any unevenness in the surface affecting one wheel is transferred over to the other wheel on the same axle, and can cause whichever end of the car to skip sideways, because they are short wheel base, any skipping is immediately obvious, and gravel just makes it worse.
In short, what you are describing, is what I would expect.
When my wife & daughter wanted to buy a Jimny, I warned them about it, they went right ahead and bought one (a 2021), and the first time they took it on a long drive and hit an uneven surface (not gravel), they complained bitterly about having to slow right down, the vehicle I was driving (a 2005 Grand Vitara) had no trouble with it.
Replied by fordem on topic Jimny in Canada
pic for attention
25 Apr 2023 17:00 #248837
by Skaguy
Thanks for the insight. The Jimny is my only car but my previous one was an 80 series Landcruiser which would just float over potholes. The difference between the two definitely made the twitchiness more noticeable.
I'll get the OME lift kit in and see how she goes. I'll also see what difference using 4x4 high makes.
Maybe I'll just have to get used to it...
Time to create page: 0.204 seconds
