inner sill
3 years 7 months ago #248700
by paul2u
inner sill was created by paul2u
i got an advisory on the inner sill off side , so i had a look at it and yes it needs a small patch , so the plan is to do this job for next year , and tips on how it best done do i need to take of the plastic trim thankyou
- Thank you received: 2004
3 years 7 months ago #248703
Replied by Lambert on topic inner sill
As with all small patches of rust expect to keep digging far more than you can see on the surface to find good metal. And yes taking the plastic off the outside isn't a bad idea even if just to prevent it melting.
3 years 7 months ago #248718
by Scimike
Replied by Scimike on topic inner sill
Welding under a vehicle is a pain unless you have good access. So if you plan to do it yourself think about the best way to get easy and comfortable access under the vehicle to access the area to repair.
If you can't gain access and it looks like your going to be welding on your back under the vehicle consider getting it done by someone with a lift etc.
Not saying it can't be done, I've done it myself, but comfort is worth considering to avoid rushed "pigeon poo weld "repairs.
You need to cut out the rust back to rust free metal, so as Lambert indicated the hole will get bigger than you can currently see.
3 years 6 months ago #248722
by paul2u
Replied by paul2u on topic inner sill
thankyou for your common sense replies , i was wondering how to get the best access to the job if i am to do it myself from the floor , i was wondering about tipping the jeep over on its side as far as i can without it falling over , perhaps the best option as you say is to get somebody with a ramp to do it thankyou it all helps in the planning lol
Time to create page: 0.073 seconds
