17" Wheels
3 years 7 months ago #248573
by tomcat
17" Wheels was created by tomcat
Suggestion has been made I go to 17" wheels.
Has anyone recommend which 17" will fit a Jimny.
All comments appreciated. Thanks
- Thank you received: 679
3 years 7 months ago #248574
Replied by DrRobin on topic 17" Wheels
I suspect the answer will be none will fit, at least not without a lot of wheel arch trimming and a reasonable suspension lift.
3 years 7 months ago #248576
by tomcat
Replied by tomcat on topic 17" Wheels
As I suspected.
Thanks for the comment.
- Thank you received: 706
3 years 7 months ago #248577
Replied by jackonlyjack on topic 17" Wheels
Look on wheel and trye calculator sites
I believe some kia/jeep are same stud pdc
Could just be an issue with centre bore
But dependant on off set of wheel a spacer would resolve centre bore issues
The following user(s) said Thank You: tomcat
3 years 7 months ago #248578
205/60/17 = 678 dia
205/65/17 = 699
standard 205/70/15 =668
215/75/15 = 704
so 60/65 profile in 17" will fit fine
a standard jimny will run 215/75/15 with no issues
205/65/17 = 699
215/75/15 = 704
- Thank you received: 2004
3 years 7 months ago #248580
Replied by Lambert on topic 17" Wheels
A while ago I was looking at 18s from a company called extreme offset steel wheels they were on bookface but it was a while ago. They were able to supply any whole inch width and et in any rim upto 20s I think stud pattern and centre weren't a problem either. As said above you just reduce the tyres profile to suit.
Time to create page: 0.116 seconds
