Not entirely Jimny related....
03 Apr 2023 11:23 #248368 by monstarghs
whats wrong with the standard screw thread 2ton that comes in the back? if you need more height take some 2x4 short planks and the its a straight lift also so no worries about changing angles? am i missing something? or is this just a ooh shiny thing
03 Apr 2023 12:45 #248372 by Roger Fairclough
The standard scissor jack is more than adequate to lift an axle enough to change a wheel and add a plywood based load spreader and you are covered for most, if not all, occasions when away from home. It's also lighter and cheaper than the skid jack mentioned.
Roger
03 Apr 2023 18:50 #248376 by Lambert
I could say the same thing about tyre tread upgrades or suspension lifts. Maybe the answer is simply, because.
04 Apr 2023 13:23 #248382 by DrRobin
If you had to jack on soft ground on a regular basis then I can see how this sled would be a good idea and if there is enough slip in the surface the jack would still move.
It's a lot of years since I have had to jack anywhere apart from at home and never on soft ground, so for flexibility a standard jack and a bit of plywood would be just as good and more versatile (it would slip on any surface) even if it does take slightly longer to deploy. You could always attach some handles to the plywood to make it easier to lift up after use.
04 Apr 2023 13:56 #248383 by Roger Fairclough
standard practice is to attach a short length of a suitable rope to pull the ply. base out of it's hole.
This reminds me of the K.I.S.S principle.
Roger
04 Apr 2023 14:35 #248385 by Scimike
Like most things it exists because it's slightly better, or fits individual circumstances better.
The standard cheap sctew jack you get with the Jimny is fine for changing a wheel, but like many I own a trolley jack as I find it physically easier to use.
So at home the trolley jack gets used for everything, never the supplied screw jack.
So, hypothetically speaking, if I was in a position that involves a lot of jacking away from home then I could be persuaded keep a trolley jack in the vehicle. Now add soft ground and a dislike of thick planks on which to balance any jack, hey presto, I am in the market for said skid jack.
Perfect example of why the standard jack is no good for me - - - - hypothetically.
But then none of this applies, which is why I have only ever used the standard screw jack to change a wheel out and about and why it's just as good. - - - but then I did wish I had my trolley jack on me when I did it
Time to create page: 0.265 seconds
