Heater Matrix - input/output pipes
28 Mar 2023 14:11 #248283 by maverick
Hi,
Does anyone know the diameter of the Heater Matrix "input/output pipes" as I need to do a flush
Jalapeño, IISY?
28 Mar 2023 14:23 #248285 by DrRobin
I don't know (I seem to remember 12mm but could be wrong) but I have been thinking I need to flush mine, so if you find out please let me know.
I assume you just disconnect the flexible pipes in the engine bay and force a bit of water through until it comes clear?
Robin
28 Mar 2023 18:56 #248291 by Lambert
It's been a while since I had the one in dreadnought changed but I want to say it was about 8 to 10mm but I'm not sure.
29 Mar 2023 12:15 #248295 by monstarghs
dont forget to turn the cabin setting to heat to open the valves, also flush both ways.
29 Mar 2023 12:39 #248296 by gv42
monstarghs wrote: dont forget to turn the cabin setting to heat to open the valves, also flush both ways.
There aren't any valves on the jimny
Jimny 2003, and 2013
The following user(s) said Thank You: Darthblaker7474
29 Mar 2023 18:04 #248311 by Mike G
The matrix pipes stick out the front of the bulkhead just behind the engine. Two rubber hoses attach directly to it. You could take a Vernier caliper to them and measure. However, I'm not a fan of throwing stuff out, I have my old matrix in the garage here. The outside diameter is 14mm on my old one which I expect is factory fitted.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
