Do I have the OEM wind deflectors installed in the right channel?
- GandHisJimny
Topic Author
- Premium Member
- Thank you received: 14
22 Mar 2023 17:56 #248170
by GandHisJimny
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
Hi all,
Recently bought the OEM wind deflectors ( suzuki-shop.co.uk/Wind-Deflector-Set--Suzuki-Jimny : SKU 00800-87530) and because I am an idiot and have never installed something like this before I cannot understand the instructions.
Are they supposed to go in the same channel as the window pane itself or the rubber outer one (where I currently have it, see photo below)?
I ask because my window has been a bit juddery & rattly since I installed them, it's clearly a tight fit, and I'm not sure if that's just down to the design or me putting it in the wrong channel. As you can see in the photo it stresses the fitting a bit, so wondering if this is right.
Ta,
George
Ta,
George
- GandHisJimny
Topic Author
- Premium Member
22 Mar 2023 17:58 #248171
by GandHisJimny
Replied by GandHisJimny on topic Do I have the OEM wind deflectors installed in the right channel?
- mark a franklin
22 Mar 2023 18:07 #248172
by mark a franklin
Replied by mark a franklin on topic Do I have the OEM wind deflectors installed in the right channel?
Not fitted right
Edge should sit on black rubber
- GandHisJimny
Topic Author
- Premium Member
22 Mar 2023 18:16 #248173
by GandHisJimny
Oh dear. So they sit in the same channel as the window itself? Buddy buddy, right up against the glass?
- mark a franklin
23 Mar 2023 15:30 #248192
by mark a franklin
This is how mine is fitted
- GandHisJimny
Topic Author
- Premium Member
28 Mar 2023 16:21 #248287
by GandHisJimny
Thank you, this was perfect and I fitted them properly after you replied but forgot to respond! No idea why it caused me so much consternation. I think I wasn't ready to bend them as much as needed!
The following user(s) said Thank You: mark a franklin
Time to create page: 0.329 seconds
