Grinding/scraping noise whilst driving
20 Mar 2023 09:28 #248108
by Ht03
Grinding/scraping noise whilst driving was created by Ht03
Hi, my jimny is making an awful grinding/ scraping noise whilst driving, sounds like a shaft is scraping against something. Is there anyway i can post a video here? The sound is coming from somewhere on the front of the vehicle. I’ve changed front drivers cv, and the shaft was fine. Changed the diff oil, no metal shavings to indicate blown diff, the noise started in 2wd also. Lockers seem to engage but I will double check by jacking it up later.
I’m completely at a loss of what it could be
- Thank you received: 1998
20 Mar 2023 09:47 #248109
Replied by Lambert on topic Grinding/scraping noise whilst driving
Have you checked the propshaft joints for excessive wear, with them connected there should be no vertical or horizontal movement and with them disconnected they should move freely but with a slight resistance.
20 Mar 2023 12:11 #248112
by LesNewell
Replied by LesNewell on topic Grinding/scraping noise whilst driving
Put it in 4x4, chock the back wheels and jack up the front axle. With the hubs unlocked both wheels should spin freely with no noise. If you get a noise it's most likely brakes or a wheel bearing. While you are there check the discs for any obvious scrapes or scoring.
Now engage the hubs and spin one wheel. The other should spin the other way. If you now get noise the problem is most likely the diff.
Next take it out of 4x4 and unlock the hubs. Make sure the car is securely supported on axle stands then climb underneath and manually turn the front prop. Listen for noises and look for any marks. As Lambert suggested give each joint a good shake to feel for any play.
- Roger Fairclough
- Thank you received: 225
20 Mar 2023 13:13 #248113
by Roger Fairclough
Replied by Roger Fairclough on topic Grinding/scraping noise whilst driving
Check for a pebble or similar jammed between disc and backing plate. I agree with Les about wheel bearings but wear in propshaft u/j's will be felt as vibration, not grinding/scraping noise.
Roger
Roger
- Roger Fairclough
20 Mar 2023 20:31 #248131
by Roger Fairclough
If the movement is in a u/j, then it needs changing but even then it wont eliminate the noise you have. If the movement is in the sliding joint, then up to a point, it is normal.
Jack the front wheels and spin each in turn. If you have a mechanics stethoscope, listen for the source of any noises and report back.
Roger
Roger
- grumyoldjoe
- Elite Member
- Thank you received: 20
20 Mar 2023 22:22 #248136
by grumyoldjoe
Wine improves with age.
Replied by grumyoldjoe on topic Grinding/scraping noise whilst driving
Is the noise there all the time?
I have similar issue but at specific revs ( 1800 and 3200)
Its appears to be coming from the CAT
Time to create page: 0.208 seconds
