Tow Bar Bike Rack.
  • Jonesie
  • Visitor
  • Visitor
05 Mar 2023 23:04 #247915 by Jonesie
Tow Bar Bike Rack. was created by Jonesie
Help required wise Jimners,
Which tow ball mounted bike racks ( obvs only need a two bike one ) are you all using?
I have noticed that Suzuki are selling one for the Gen 4…..
Thanks wise ones.
jonesie
06 Mar 2023 07:32 - 06 Mar 2023 07:36 #247920 by Scimike
Replied by Scimike on topic Tow Bar Bike Rack.
I have a Thule 3 bike which works well on the various vehicles I have owned.
It works on the Jimny, BUT I need to remove the spare as its just not quite got enough clearance to miss the door mounted spare. This is with a Witter swan neck bar and standard sized spare, it's also a G3. It folds flat to allow you access to the vehicle with the unit attached, but this is a useless idea when the bikes are fitted as it too heavy / awkward to use. So assume you won't be able to get the rear door open when fitted.
So my take away is check any suggestions are 100% the same configuration as your vehicle or check before you purchase. I would assumed the Suzuki offering is designed to avoid such problems, but will be designed for a Suzuki tow bar and std sized spare.
Last edit: 06 Mar 2023 07:36 by Scimike.
06 Mar 2023 13:45 #247926 by Lambert
Replied by Lambert on topic Tow Bar Bike Rack.
Also remember to be mindful of the additional width if carrying adult bikes as a Jimny is quite narrow.
06 Mar 2023 16:11 #247927 by RumbleAndSway
Replied by RumbleAndSway on topic Tow Bar Bike Rack.
This is good advice.
I have a Buzzrack Scorpion  buzzrack.com/galleries/e-scorpion-1/ but a 29” mountain bike protrudes massively either side of a Jimny.  Too much to be safe in my part of the world.  As a result i never use it.
The Frontrunner roof-bar solution works: www.frontrunneroutfitters.com/en/uk/pro-...arrier-power-ed.html
However, not a great solution for those without height and strength.
Anyone tried “The Rack” from Scorpion Racks? Expensive but may have appeal.
  • Jonesie
  • Visitor
  • Visitor
06 Mar 2023 19:06 #247934 by Jonesie
Replied by Jonesie on topic Tow Bar Bike Rack.
I fancy the “Rack” Rumble but not sure they are still at it?
Like you say most MTB’s are wider than a Jim.
Not really interested in putting the bike on the roof but seems one of the only solutions.
Time to create page: 0.129 seconds
