Front Wheel bearing retaining nut
- Rev dennis
03 Mar 2023 18:18 #247869
by Rev dennis
Front Wheel bearing retaining nut was created by Rev dennis
So today I foolishly thought changing a front wheel bearing would be straight forward. Using the correct tool I broke 3 ratchets and the tool itself to try and remove the retaining nut behind the small plate that is in front of the circlip.
it did not budge one bit.
03 Mar 2023 23:26 #247877
by facade
Replied by facade on topic Front Wheel bearing retaining nut
Did you undo the stake on the nut first?
They are really tight (220Nm), and with the stake still in as well it will be virtually impossible to shift it.
It could have been locktited by a previous owner, the easiest way to shift it will be to warm it up, you are replacing the bearing & seal anyway
You did well to snap a decent ratchet, I'm not that strong anymore. If you are working LandRover style, with a scaffold pole you should always use a cracker bar not a ratchet.
The following user(s) said Thank You: Rev dennis
- Rev dennis
08 Mar 2023 19:18 #247984
by Rev dennis
Replied by Rev dennis on topic Front Wheel bearing retaining nut
A massive thankyou to facade for pointing me in the right direction. I purchased a long breaker bar and managed to get them both off. Decided to go the whole hog and replace the kingpins and seals, wheel bearings and brakes.
Time to create page: 0.242 seconds
