4 inch lift kit 1 or 2 prop spacers
10 Feb 2023 13:49 #247520 by Roger Fairclough
How far you get is partly down to the vehicle and partly down to the driver. I have been a passenger in a basic Toyota driven in a competent manner that easily got through a hazard whereas the same model but modified and driven in an aggressive manner failed. Going too far on your modifications can easily result in a motor that becomes uncomfortable to drive and is likely to fail more easily. It is better to improve your skills than to modify your vehicle to try and compensate for other things. Remember, fast as necessary, slow as passible.
A 4" lift is viewed with distrust because what you gain - 4" lift under the body and chassis but not under the diffs. is outweighed by the reduction in stability.
Roger
Time to create page: 0.189 seconds
