Re:Gen 4 Clutch Slave Cylinder - Replace
13 Jan 2023 23:08 #246876 by Bob1050
Just been on You Tube and failed to spot a guide to replacing a Gen 4 Jimny Clutch Slave Cylinder. Before I go crawling about on a cold wet driveway - has anyone done this or have an 'Idiot's Guide'? In short - is this an easy diy job or an awkward job best left to a professional now the car is out of warranty?
14 Jan 2023 03:27 #246877 by Lambert
It can't be that far out of warranty, I'd be arguing with the dealer that they covered at least some part of the cost. A clutch is after all a fundamental system on the car, it's not like wanting a set of brake pads or a wiper blade.
14 Jan 2023 09:11 #246879 by Roger Fairclough
Implying that brake pads and wiper blades are not fundamental systems on a car is a very strange concept, after all, every car has them!
A more pertinent point is "why do you think the slave cylinder is faulty"?
Roger
14 Jan 2023 10:16 #246881 by Lambert
Roger
But they are not items you would expect to replace under warranty unlike a clutch cylinder.
14 Jan 2023 11:04 #246882 by Roger Fairclough
Wiper blades are subject to wear and tear due to heavy usage and 3 years in adverse conditions will easily damage them to the point of needing replacement. Brake pads can also suffer wear beyond what you would normally expect especially with high mileage and unnecessary braking. Tail gating comes to mind with that one. Normally a slave cylinder is such a simple device that I would not expect it to give trouble in 3 years and I doubt that a dealership would expect to replace one on a car that is only recently out of warranty, which brings me back to my point about why does the owner think his problem is related to the slave cylinder?
Roger
14 Jan 2023 11:42 #246884 by Roger Fairclough
Coming back to the original question, the slave cylinder - Suzuki call it the operating cylinder - is easy to get to and simple to remove but like most things on a car require a degree of mechanical knowledge and tools to do it. If you have a friend who has both then maybe asking them for advice would be a sensible option.
Roger
Time to create page: 0.172 seconds
